    MMM-Tado - Tado API Login no longer working (403 error) — any fix?
    17 Posts 7 Posters 4.1k Views 9 Watching
    • mumblebajM
      mumblebaj Module Developer @chichi1887
      @chichi1887 I have seen that the node-tado-client npmjs package has been updated to v1.0.0 to cater for the new OAuth2 flow. I would suggest opening an issue on the module Github page for the module developer to fix.
      M 1 Reply Last reply
        mishu28nmv @mumblebaj
        https://github.com/WouterEekhout/MMM-Tado/issues/18
        There is a fix from an user. Maybe give it a try 😁
        J 1 Reply Last reply
          JoeFranz @mishu28nmv
          @mishu28nmv
          What exactly do I need to do to get MMM-Tado working again? I searched the logs for the URL that should be generated, but couldn’t find anything.
            sdetweil @JoeFranz
            @JoeFranz did you look at the fork
            https://github.com/daydy16/MMM-Tado
              JoeFranz @sdetweil
              @sdetweil I read it, but I can’t find the URL in the logs… :-(
                sdetweil @JoeFranz
                @JoeFranz oh, i see
                are you sure this new module is installed instead of the one you were trying?
                J C 2 Replies Last reply
                  JoeFranz @sdetweil
                  @sdetweil I’ve now reinstalled it from this site. I can’t find the URL in the logs.
                    sdetweil @JoeFranz
                    @JoeFranz how are you displaying the logs?
                      JoeFranz @sdetweil
                      @sdetweil pm2 logs MagicMirror
                        sdetweil @JoeFranz
                        @JoeFranz probably need more lines
                        pm2 logs MagicMirror --lines=100
                          JoeFranz @sdetweil
                          @sdetweil said in MMM-Tado - Tado API Login no longer working (403 error) — any fix?:
                          OK, the URL is now displayed :-)
                          I’ll try it out, thanks!
                            chichi1887 @sdetweil
                            @sdetweil Hi i reinstall the hole MM Software and use the daydy16 Tado Version but from the beginning with alle the config i became this error 8857d2f8-4886-4377-ba64-0f68710eaec6-image.png what i do wrong
                            C 1 Reply Last reply
                              chichi1887 @chichi1887
                              i Spend now 4 Nights with Chatgpt without Outcome. Only the handle Version change the Bearer works great.
                              D 1 Reply Last reply
                                det @chichi1887
                                @chichi1887 said in MMM-Tado - Tado API Login no longer working (403 error) — any fix?:
                                Did you find a solution?
                                Thank you.
                                N 1 Reply Last reply
                                • N
                                  nero32 @det
                                  @det I have the same problem.
                                    mishu28nmv
                                    This is my solution. Just install the https://github.com/daydy16/MMM-Tado
                                    In the config file:
                                    		module: 'MMM-Tado',
                                    		position: 'bottom_left', // This can be any of the regions.
                                    		updateInterval: 900000 // miliseconds-15minutes-96times per day < 100
                                    After you launch your Mirror with “node --run start”, you receive in the terminal this:
                                    MMM-Tado: Device authentication required. Please visit the following URL:
                                    https://login.tado.com/oauth2/device?user_code=XXXXXX
                                    You put that URL in your browser and submit the code. That’s it.
                                    Hope it helps!
