    MMM-Tado - Tado API Login no longer working (403 error) — any fix?
    17 Posts 7 Posters 2.5k Views 9 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @chichi1887
      @chichi1887 I have seen that the node-tado-client npmjs package has been updated to v1.0.0 to cater for the new OAuth2 flow. I would suggest opening an issue on the module Github page for the module developer to fix.
        mishu28nmv @mumblebaj
        https://github.com/WouterEekhout/MMM-Tado/issues/18
        There is a fix from an user. Maybe give it a try 😁
          JoeFranz @mishu28nmv
          @mishu28nmv
          What exactly do I need to do to get MMM-Tado working again? I searched the logs for the URL that should be generated, but couldn’t find anything.
            sdetweil @JoeFranz
            @JoeFranz did you look at the fork
            https://github.com/daydy16/MMM-Tado
              JoeFranz @sdetweil
              @sdetweil I read it, but I can’t find the URL in the logs… :-(
                sdetweil @JoeFranz
                @JoeFranz oh, i see
                are you sure this new module is installed instead of the one you were trying?
                J C 2 Replies Last reply Reply Quote 0
                  JoeFranz @sdetweil
                  @sdetweil I’ve now reinstalled it from this site. I can’t find the URL in the logs.
                    sdetweil @JoeFranz
                    @JoeFranz how are you displaying the logs?
                      JoeFranz @sdetweil
                      @sdetweil pm2 logs MagicMirror
                        sdetweil @JoeFranz
                        @JoeFranz probably need more lines
                        pm2 logs MagicMirror --lines=100
