    MMM-SolarPicture
    14 Posts 7 Posters 8.0k Views 8 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @qu1que
      @qu1que said in MMM-SolarPicture:
      looks great next to the MMM-Lunartic module.
      :thumbsup:
      • G
        grena Module Developer @qu1que
        I wonder if it will be possible to show all the images from the SDO website one after the other, setting the time between one and another, so you can see them all consecutively.
        This functionality was simple to integrate into the module… It’s now possible to activate an automatic slideshow of all images !
        To do this, simply add the transitionInterval option in your configuration with display time of one image before moving to the next in milliseconds ;)
        To update the module:
        cd ~/MagicMirror/modules/MMM-SolarPicture
        git pull
        Happy Christmas :christmas_tree:
        qu1queQ 1 Reply Last reply
        Reply Quote 2
        • qu1queQ
          qu1que Project Sponsor @grena
          @grena
          Cool!! It works like a charm! Thanks for your work.
            bugphunk
            Hello everyone!
            First of all: Thanks for the module! I like it a lot.
            I tried to move the picture around by adding a new position in my custom.css but it is not moving at all. The MMM.MoonPhase module moves without a problem, but these paramaters don´t work for the sun (because of the missing *.css file, I guess). I´m no expert at all, therefore a little help would be highly appreciated!
            My goal is to push the sun “outside” the screen so that only the upper left corner of the sun is on the bottom right side of the screen.
            Thanks in advance and kind regards,
            Marco
            S G 2 Replies Last reply
              sdetweil @bugphunk
              @bugphunk i do not know, but use the developer window elements tab to discover and set css styles to determine what needs to go in custom.css
              see the second link in my signature below
              • G
                grena Module Developer @bugphunk
                Hello @bugphunk,
                I’m not sure I fully understand what you want to do… But to move a module, use the position option. An illustration of the different zones is available here
                If you do not get the desired result, you must look for the custom CSS code!
                The module displays a simple img in a div… The absence of a CSS file in MMM-SolarPicture should simplify things because everything is managed by MM!
                Grena
                  bugphunk
                  Thanks for your support. The developer window elements tab might do the trick.
                    bugphunk
                    Got it! Thanks again!
                    R plainbrokeP 2 Replies Last reply
                      rkorell Module Developer @bugphunk
                      @bugphunk cool!
                      It would be nice if you post here, how you did this get done…
                      Regards,
                      Ralf
                      • plainbrokeP
                        plainbroke @bugphunk
                        @bugphunk
                        Ditto on how you got to this point that looks really nice.
                          bugphunk
                          Hi folks, I’m no expert at all and it was a lot of trial and error. I used the lower_third position because there aren’t any other modules in that position which were also moving around the screen when changing the position of MMM-Solar-Picture. Also the NASA-watermark is still there in the upper left corner of the shown solar picture. It is just hidden behind the Earth module, so that worked out for me. My config.js on a 1080p screen
                                  module: "MMM-SolarPicture", //IGNORED
                                  position: "lower_third",
                                          imageType: 'AIA 304',
                                          updateInterval: 1 * 60 * 60 * 1000, //(1 hour)
                                          maxMediaWidth: 1200,
                                          maxMediaHeight: 1200
                          I added these lines to my custom.css
                          .MMM-SolarPicture img {
                          position: absolute;
                          top: +100px;
                          left: +1100px;
                          opacity: 1 !important;
                          Good luck with moving around your sun and kind regards
