    MMM-SolarPicture
    14 Posts 7 Posters 5.3k Views 8 Watching
    • qu1queQ Offline
      qu1que Project Sponsor
      Very nice module!! I just tested it and it looks great next to the MMM-Lunartic module.
      I wonder if it will be possible to show all the images from the SDO website one after the other, setting the time between one and another, so you can see them all consecutively.
      Great work. Thanks for sharing!
      Greetings, Quique.
      Mykle1M G 2 Replies Last reply Reply Quote 1
        Mykle1 Project Sponsor Module Developer @grena
        @grena said in MMM-SolarPicture:
        I hope you like the module.
        Nice work! I wish I thought of it first. ;-)
          Mykle1 Project Sponsor Module Developer @qu1que
          @qu1que said in MMM-SolarPicture:
          :thumbsup:
          • G Offline
            grena Module Developer @qu1que
            This functionality was simple to integrate into the module… It’s now possible to activate an automatic slideshow of all images !
            To do this, simply add the transitionInterval option in your configuration with display time of one image before moving to the next in milliseconds ;)
            To update the module:
            cd ~/MagicMirror/modules/MMM-SolarPicture
            git pull
            Happy Christmas :christmas_tree:
            qu1queQ 1 Reply Last reply Reply Quote 2
            • qu1queQ Offline
              qu1que Project Sponsor @grena
              @grena
              Cool!! It works like a charm! Thanks for your work.
                bugphunk
                Hello everyone!
                First of all: Thanks for the module! I like it a lot.
                I tried to move the picture around by adding a new position in my custom.css but it is not moving at all. The MMM.MoonPhase module moves without a problem, but these paramaters don´t work for the sun (because of the missing *.css file, I guess). I´m no expert at all, therefore a little help would be highly appreciated!
                My goal is to push the sun “outside” the screen so that only the upper left corner of the sun is on the bottom right side of the screen.
                Thanks in advance and kind regards,
                Marco
                S G 2 Replies Last reply Reply Quote 0
                  sdetweil @bugphunk
                  @bugphunk i do not know, but use the developer window elements tab to discover and set css styles to determine what needs to go in custom.css
                  see the second link in my signature below
                  • G Offline
                    grena Module Developer @bugphunk
                    Hello @bugphunk,
                    I’m not sure I fully understand what you want to do… But to move a module, use the position option. An illustration of the different zones is available here
                    If you do not get the desired result, you must look for the custom CSS code!
                    The module displays a simple img in a div… The absence of a CSS file in MMM-SolarPicture should simplify things because everything is managed by MM!
                    Grena
                      bugphunk
                      Thanks for your support. The developer window elements tab might do the trick.
                        bugphunk
                        Got it! Thanks again!
                        R plainbrokeP 2 Replies Last reply Reply Quote 0
