    Touch screen over two way mirror
    48 Posts 20 Posters 60.3k Views 19 Watching
    • AlessandroRaA
      AlessandroRa
      I’m still working on my mirror, but I’ve bought a IR frame from aliexpress and it works good!
      L cowboysdudeC 2 Replies Last reply
        r0mantic0
        Hi all…
        I would also like to make my own magic mirror photo booth. I did a lot of research on internet. Who could solve the issue of the touchscreen functionality using a two way mirror? Does it work like this, that you put an IR frame on the mirror? Which IR frame did you choose? and my last question… which mirror booth software did you choose?
        Thanks a lot
        • brobergB
          broberg Project Sponsor
          IR-frame or touchfoil would work, IR frames are slightly cheaper and touchoils have the advantage that they are mounted on the inside instead of the outside
          R 1 Reply Last reply
            r0mantic0 @broberg
            @broberg thanks a lot for this first information… can I buy every two way mirror for this, or should I consider something special?
            brobergB R 2 Replies Last reply
            • brobergB
              broberg Project Sponsor @r0mantic0
              @r0mantic0 you can get any mirror you like, neither the ir frame or touchfoil cares about what mirror you use.
              The only thing I can think of is that the touchfoil could be a bit cranky if you use an acrylic mirror and not glass, due to the fact that touchfoils are capacative.
                r0mantic0 @r0mantic0
                @r0mantic0 I was thinking to use a mirror from the company Pilkington (MirroView OR Mirropane Spy). Then I think the IR frame should 100% work, but maybe it is better to use a touchfoil in this case (?)
                brobergB 1 Reply Last reply
                • brobergB
                  @r0mantic0 the pilkington mirroview will be a good choice, personally I would go with the touchfoil, then you have no limitations on how the frame is built, the ir frame need to protrude a bit from the glass.
                  • L
                    l8kerjuan @AlessandroRa
                    @AlessandroRa could you post a link to item you purchased?
                      r0mantic0
                      I asked the company infotronik for the touch foil, the answer was:
                      the problem with the touch foil: the mirror contain metalic components which would cause problems using the touch foil
                      the problem with the IR frame is that it can’t be used behind the mirror
                      so i thing the best solution would be the IR frame… but in some forums I was reading also that with the mirror can be used either a touch foil or the IR frame… hmmm, now I am confused
                      • brobergB
                        @r0mantic0 Haven’t thought about that at all, so had to try it, and they are indeed correct, the metal coating in the mirror acts as a conductor and anywhere you touch on the mirror gets amplified over the entire area. And thus renders the touchfoil useless.
                        Crap.
                        Need a new solution for my own mirror now.
                        • cowboysdudeC
                          cowboysdude Module Developer @AlessandroRa
                          @AlessandroRa said in Touch screen over two way mirror:
                          Which size did you get?
                          • 1m21
                            1m2
                            Anyone have a forum or link for the photobooth builds?
                            This would also be so fun to build and have but on the coding side I’m no expert. On every thing else I’m handy enough to find solutions I think.
                            • cowboysdudeC
                              cowboysdude Module Developer @1m2
                              @1m2 Look up to the top and ask that guy… he wanted one too… maybe he found a way.
                                Marko
                                is anybody solve the problem with foil behind mirror? I asked several company’s for info and thay tell me that Projected capacitive will be the best sollution but miror may not contain metal inside. Is thare mirror / glass that is good to use with foil which does not create interference?
                                Is somebody succeed with this?
                                  spacevolt @Marko
                                  @Marko I would also like to know what type of two way mirror is best for PCAP foils/screens!
                                  • H
                                    Hoosierdad
                                    i found this website
                                    https://www.twowaymirrors.com/smart-mirror/
                                      A Former User
                                      Thank you Hoosierdad
                                      I found this site ,but it doesn’t deliverry to Romania…:)
                                        ranger33 @nat
                                        @nat know I miss very late but I now have experience with this!! I bought a touch screen overlay from PQ Labs and then I removed the glass sheet that came with it and replaced it with glass from www.twowaymirrors.com I made sure my glass fit perfectly and boom touchscreen mirror!
                                        H 1 Reply Last reply
                                        • H
                                          Hoosierdad @ranger33
                                          @ranger33 said in Touch screen over two way mirror:
                                          PQ Labs
                                          I looked in their store and could not find the overlay, how much did it cost and is it a special order item?
                                          also what Gen was it?
                                            ranger33 @Hoosierdad
                                            @Hoosierdad google Peau Productions touch screen overlay it should come up! But yes you have to email them for an invoice! I ordered the no longer posted G4S overlay and it works great as it’s the only one with sizes small 32"
