    Touch screen over two way mirror
    48 Posts 20 Posters 59.8k Views 19 Watching
      broberg Project Sponsor @r0mantic0
      @r0mantic0 the pilkington mirroview will be a good choice, personally I would go with the touchfoil, then you have no limitations on how the frame is built, the ir frame need to protrude a bit from the glass.
      • L
        l8kerjuan @AlessandroRa
        @AlessandroRa could you post a link to item you purchased?
          r0mantic0
          I asked the company infotronik for the touch foil, the answer was:
          the problem with the touch foil: the mirror contain metalic components which would cause problems using the touch foil
          the problem with the IR frame is that it can’t be used behind the mirror
          so i thing the best solution would be the IR frame… but in some forums I was reading also that with the mirror can be used either a touch foil or the IR frame… hmmm, now I am confused
            @r0mantic0 Haven’t thought about that at all, so had to try it, and they are indeed correct, the metal coating in the mirror acts as a conductor and anywhere you touch on the mirror gets amplified over the entire area. And thus renders the touchfoil useless.
            Crap.
            Need a new solution for my own mirror now.
            • cowboysdudeC
              cowboysdude Module Developer @AlessandroRa
              @AlessandroRa said in Touch screen over two way mirror:
              I’m still working on my mirror, but I’ve bought a IR frame from aliexpress and it works good!
              Which size did you get?
                1m2
                Anyone have a forum or link for the photobooth builds?
                This would also be so fun to build and have but on the coding side I’m no expert. On every thing else I’m handy enough to find solutions I think.
                • cowboysdudeC
                  cowboysdude Module Developer @1m2
                  @1m2 Look up to the top and ask that guy… he wanted one too… maybe he found a way.
                    Marko
                    is anybody solve the problem with foil behind mirror? I asked several company’s for info and thay tell me that Projected capacitive will be the best sollution but miror may not contain metal inside. Is thare mirror / glass that is good to use with foil which does not create interference?
                    Is somebody succeed with this?
                      spacevolt @Marko
                      @Marko I would also like to know what type of two way mirror is best for PCAP foils/screens!
                      • H
                        Hoosierdad
                        i found this website
                        https://www.twowaymirrors.com/smart-mirror/
                          A Former User
                          Thank you Hoosierdad
                          I found this site ,but it doesn’t deliverry to Romania…:)
                            ranger33 @nat
                            @nat know I miss very late but I now have experience with this!! I bought a touch screen overlay from PQ Labs and then I removed the glass sheet that came with it and replaced it with glass from www.twowaymirrors.com I made sure my glass fit perfectly and boom touchscreen mirror!
                            H 1 Reply Last reply Reply Quote 1
                            • H
                              Hoosierdad @ranger33
                              @ranger33 said in Touch screen over two way mirror:
                              PQ Labs
                              I looked in their store and could not find the overlay, how much did it cost and is it a special order item?
                              also what Gen was it?
                                ranger33 @Hoosierdad
                                @Hoosierdad google Peau Productions touch screen overlay it should come up! But yes you have to email them for an invoice! I ordered the no longer posted G4S overlay and it works great as it’s the only one with sizes small 32"
                                • H
                                  @ranger33 so you built a magic mirror with touch capability did your Fram go around the glass it self or behind the glass behind the monitor?
                                    @Hoosierdad Yes i built a magic mirror with touch capability, I’d be happy to send you pictures! I built my frame over top of the monitor and the glass so the only thing seen was the screen. It went over top the glass.
                                    H A 2 Replies Last reply Reply Quote 0
                                    • H
                                      @ranger33 Yes please! that would be helpful.
                                      i want to make mine similar to THIS
                                        @Hoosierdad yeah! mine functions similarly but i have no idea what software he’s running i just know it’s beautiful!
                                        https://drive.google.com/file/d/0B_AMuS6x7qvNUjZETXI0dkJ2NTQ/view?usp=sharing
                                        https://drive.google.com/file/d/0B_AMuS6x7qvNVlNqVGVrVzJ3U1k/view?usp=sharing
                                        • H
                                          thanks i will check it out later, i’m at work and our proxy server blocks google drive. what i really want to do is make a selfie booth. i have different software i plan on running, thanks again. I’ll be in touch
