    Looking for Beta-testers!
    Scheduled Pinned Locked Moved MagicMirror
    56 Posts 17 Posters 66.6k Views 18 Watching
    • E Offline
      ESOB @morozgrafix
      Something on the develop branch turned my magic mirror back to black screen again (It ran fine on develop branch yesterday but when I did my pull&&install today it went down again). Here is the information from the pm2 logs, tell me if you need anything else:
      mm-0 (out): Module helper loaded: MMM-NFL
      mm-0 (out): Initializing new module helper ...
      mm-0 (out): Module helper loaded: newsfeed
      mm-0 (out): All module helpers loaded.
      mm-0 (out): Starting server op port 8080 ...
      mm-0 (out): Server started ...
      mm-0 (out): Connecting socket for: MMM-Remote-Control
      mm-0 (out): Starting node helper for: MMM-Remote-Control
      mm-0 (out): Connecting socket for: calendar
      mm-0 (out): Starting node helper for: calendar
      mm-0 (out): Connecting socket for: MMM-Traffic
      mm-0 (out): MMM-Traffic helper started ...
      mm-0 (out): Connecting socket for: MMM-WunderGround
      mm-0 (out): MMM-WunderGround helper started ...
      mm-0 (out): Connecting socket for: MMM-NFL
      mm-0 (out): Starting module: MMM-NFL
      mm-0 (out): Connecting socket for: newsfeed
      mm-0 (out): Starting module: newsfeed
      mm-0 (out): Sockets connected & modules started ...
      mm-0 (out): Launching application.
      mm-0 (err):     at exports._exceptionWithHostPort (util.js:1049:20)
      mm-0 (err):     at Server._listen2 (net.js:1253:14)
      mm-0 (err):     at listen (net.js:1289:10)
      mm-0 (err):     at net.js:1399:9
      mm-0 (err):     at _combinedTickCallback (internal/process/next_tick.js:77:11)
      mm-0 (err):     at process._tickCallback (internal/process/next_tick.js:98:9)
      mm-0 (err):     at Module.runMain (module.js:592:11)
      mm-0 (err):     at run (bootstrap_node.js:402:7)
      mm-0 (err):     at startup (bootstrap_node.js:157:9)
      mm-0 (err):   code: 'EADDRINUSE',
      mm-0 (err):   errno: 'EADDRINUSE',
      mm-0 (err):   syscall: 'listen',
      mm-0 (err):   address: '::',
      mm-0 (err):   port: 8080 }
      mm-0 (err): ERROR! Could not find main module js file.
      morozgrafixM 1 Reply Last reply Reply Quote 0
      • morozgrafixM Offline
        morozgrafix Moderator @ESOB
        @ESOB looks like your port 8080 is in use. Do you happen to have another instance of MM running already? Or maybe something else is taking your port 8080.
        • E Offline
          ESOB @morozgrafix
          @morozgrafix maybe, I issued a pm2 stop and then did a restart and I am no longer getting that error. I am still getting a black only screen with the only error being:
          "ERROR! Could not find main module js file."
          What logs should I get you to figure out the reason for lack of display?
          Edit:
          Scratch that, I double checked the logs and I get the same error. I will do a full pi reboot again to triple check but it seems consistent.
          Edit 2:
          After triple check, only one MM instance open and same error noted about port 8080.
          morozgrafixM 2 Replies Last reply Reply Quote 0
            @ESOB did you run npm install after pulling development branch? Next step would be to try to start it in node serveronly mode and point your browser at http://:8080 or run npm start Dev and see if you get any errors in console log of the browser or electron app
              @ESOB sorry I was replying before you edited post with update. Try temporarily changing your config.js to another port if 8080 is taken for some reason.
              • E Offline
                ESOB @morozgrafix
                @morozgrafix So I tried changing the port number to 8081 and I got this:
                mm-0 (err): WARNING! Could not load config file. Starting with default configuration. Error found: RangeError: "port" argument must be >= 0 and < 65536
                mm-0 (err): App threw an error during load
                mm-0 (err): RangeError: "port" argument must be >= 0 and < 65536
                mm-0 (err):     at assertPort (internal/net.js:17:11)
                mm-0 (err):     at Server.listen (net.js:1371:7)
                mm-0 (err):     at new Server (/home/pi/MagicMirror/js/server.js:20:9)
                mm-0 (err):     at /home/pi/MagicMirror/js/app.js:193:18
                mm-0 (err):     at loadNextModule (/home/pi/MagicMirror/js/app.js:142:5)
                mm-0 (err):     at /home/pi/MagicMirror/js/app.js:137:6
                mm-0 (err):     at Class.loaded (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:19:3)
                mm-0 (err):     at loadModule (/home/pi/MagicMirror/js/app.js:118:6)
                mm-0 (err):     at loadNextModule (/home/pi/MagicMirror/js/app.js:135:5)
                I did run npm install, also tried serveronly and running npm start dev but did not gather any additional information. I will say the weird thing is when I leave it on port 8080, the remote control module still loads.
                  @ESOB This error WARNING! Could not load config file. seems very odd. Can you please post your config.js file? Also another option is to backup your config.js and do file copy of config.js.sample to config.js to have good known configuration to begin with.
                  When starting with npm start dev or node serveronly do you see any errors in the Console Log of the dev tools of the electron or your browser?
                  P.S. I wanted to fork this troubleshooting conversation into a separate thread, but can’t seem to find a way.
                    @roramirez & @MichMich looks like develop branch got broken with this commit https://github.com/MichMich/MagicMirror/commit/354b745c39a19915c3a8547445a5049555bd37ff#diff-75953debd6cf3faf33d4ff10e8353645R11
                    Line 11 of defaults.js got this change port: process.env.MM_PORT || 8080, and server is not starting up throwing error in the console log:
                    Uncaught ReferenceError: process is not defined
                        at defaults.js:11
                    (anonymous) @ defaults.js:11
                      roramirez Core Contributors @morozgrafix
                      @morozgrafix Yes, it’s a some things I’ve seen a few minutes ago.
                      Already pushed a Hotfix. Its not the most elegant soluction of the world but it work. If there something can be better is welcome ;)
                      Ps: Pull request is https://github.com/MichMich/MagicMirror/pull/676
                        @ESOB Thanks for flagging the issue. @roramirez thanks for the fix
                        • MichMichM Offline
                          MichMich
                          Hotfix Merged! :)
                          • justjim1220J Offline
                            justjim1220 Module Developer
                            I tried this command:
                            git checkout --track origin/develop
                            And got this return:
                            fatal: Not a git repository (or any of the parent directories): .git
                            How do I change to developer mode?
                            Jim Hallock - 1995
                            • strawberry 3.141S Offline
                              strawberry 3.141 Project Sponsor Module Developer @justjim1220
                              @justjim1220 did you clone or downloaded magicmirror?
                                justjim1220 Module Developer @strawberry 3.141
                                @strawberry-3.141 I used git bash…
                                git clone https://github.com/MichMich/MagicMirror.git
                                Jim Hallock - 1995
                                • 3 / 3
