    [Remote-Control] Versions not visible
    9 Posts 3 Posters 4.5k Views 3 Watching
      schlachtkreuzer6 @Jopyth
      @Jopyth I have tried updating the module, but nothing changed?! first i tried it with git pull - up to date, and also with the installer… anyway the installer looks great! :D
      if i git fetch and git tag (without s cause “tags” did not work) i´ll see this versions:
      v2.0.0
      v2.0.1
      v2.0.2
      v2.0.3
      v2.0.4
      v2.0.5
      v2.1.0
      but you are talking about version 1.1.2? i don´t get it ^^
      • Y Offline
        yawns Moderator @schlachtkreuzer6
        @schlachtkreuzer6
        v2.0.0 - v2.1.0 are version numbers of MagicMirror, not this specific module.
        Are you sure you are working in ~/MagicMirror/modules/MMM-Remote-Control as written here? https://github.com/Jopyth/MMM-Remote-Control#update
          schlachtkreuzer6 @yawns
          and with tags: 0_1486126466527_git tags.PNG
          • Y Offline
            yawns Moderator
            weird. If you run ls -la do you see a folder called .git ?
              Jopyth Moderator @schlachtkreuzer6
              @schlachtkreuzer6 How did you install the module? It sounds like you may have downloaded a zipped version? Or did you use the installer or git clone https://github.com/Jopyth/MMM-Remote-Control.git? Edit: Also please do @yawns suggestion, if the folder does not exist, something went wrong with cloning/initializing the git repository.
                @yawns in the MM directory or module directory? in the module:
                  @Jopyth First install, was 2 or 3 months ago, after installing some modules i git clone your module like in the readme. then i saw your post with the update und tried from the MM-remote-controle directory git pull, and it says it´s already up to date. so then i tried the installer with master branch (developer didn´t work) 0_1486142532876_installer.PNG
                  • Y Offline
                    @schlachtkreuzer6
                    Right. The .git folder is not there, so git does not recognize this repository.
                    I’d suggest to remove the entire folder and git clone again.
                      @yawns thaaaaaanks for your advice :thumbsup_tone1:
