    [Remote-Control] Versions not visible
    9 Posts 3 Posters 4.2k Views 3 Watching
    • schlachtkreuzer6S Offline
      schlachtkreuzer6 @yawns
      and with tags: 0_1486126466527_git tags.PNG
      • yawnsY Offline
        yawns Moderator
        weird. If you run ls -la do you see a folder called .git ?
        schlachtkreuzer6S 1 Reply Last reply Reply Quote 2
          Jopyth Moderator @schlachtkreuzer6
          @schlachtkreuzer6 How did you install the module? It sounds like you may have downloaded a zipped version? Or did you use the installer or git clone https://github.com/Jopyth/MMM-Remote-Control.git? Edit: Also please do @yawns suggestion, if the folder does not exist, something went wrong with cloning/initializing the git repository.
          schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
            @yawns in the MM directory or module directory? in the module:
              schlachtkreuzer6 @Jopyth
              @Jopyth First install, was 2 or 3 months ago, after installing some modules i git clone your module like in the readme. then i saw your post with the update und tried from the MM-remote-controle directory git pull, and it says it´s already up to date. so then i tried the installer with master branch (developer didn´t work) 0_1486142532876_installer.PNG
              • yawnsY Offline
                yawns Moderator @schlachtkreuzer6
                @schlachtkreuzer6
                Right. The .git folder is not there, so git does not recognize this repository.
                I’d suggest to remove the entire folder and git clone again.
                schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
                  @yawns thaaaaaanks for your advice :thumbsup_tone1:
