    [Remote-Control] Versions not visible
    9 Posts 3 Posters 4.3k Views 3 Watching
      Jopyth Moderator @schlachtkreuzer6
      @schlachtkreuzer6 How did you install the module? It sounds like you may have downloaded a zipped version? Or did you use the installer or git clone https://github.com/Jopyth/MMM-Remote-Control.git? Edit: Also please do @yawns suggestion, if the folder does not exist, something went wrong with cloning/initializing the git repository.
      schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
      • schlachtkreuzer6S Offline
        schlachtkreuzer6 @yawns
        @yawns in the MM directory or module directory? in the module:
          schlachtkreuzer6 @Jopyth
          @Jopyth First install, was 2 or 3 months ago, after installing some modules i git clone your module like in the readme. then i saw your post with the update und tried from the MM-remote-controle directory git pull, and it says it´s already up to date. so then i tried the installer with master branch (developer didn´t work) 0_1486142532876_installer.PNG
          • yawnsY Offline
            yawns Moderator @schlachtkreuzer6
            @schlachtkreuzer6
            Right. The .git folder is not there, so git does not recognize this repository.
            I’d suggest to remove the entire folder and git clone again.
            schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
              @yawns thaaaaaanks for your advice :thumbsup_tone1:
