    3 tries 3 fails Raspberry b+
    28 Posts 7 Posters 24.1k Views 7 Watching
    • I Offline
      infamoustiggr
      Ah. Am I right in thinking the tutorial for the pi 0 will do it? Might get out of bed and have a play…
      • cowboysdudeC Offline
        Does everything install correctly?
        What do you mean you can’t get it to start? What happens?
        • I Offline
          infamoustiggr
          I’ve followed the guide from
          http://blog.dylanjpierce.com/raspberrypi/magicmirror/tutorial/2015/12/27/build-a-magic-mirror.html
          And
          http://michaelteeuw.nl/post/83916869600/magic-mirror-part-vi-production-of-the
          And neither work I’m afraid. No error messages, nothing notes a file/programme missing, nada. Just get to the point where it should “work” and nothing happens.
          I’ll try the pi 0 tutorial and see how that goes. It’s just that I have a spare pi b and all parts, and it’s a shame I can’t get it to go…
            cowboysdude Module Developer @infamoustiggr
            @infamoustiggr Well that’s because you need to do this way…
            https://github.com/MichMich/MagicMirror
            The instructions are in full and easy to follow there ;) The other places may not be up-to-date. The instructions in the link above are for this mirror exactly …
            There’s two ways:
            Automatic Installer (Raspberry Pi Only!)
            or
            Manual Installation
              Mykle1 Project Sponsor Module Developer @infamoustiggr
              @infamoustiggr
              Yup, cowboydude is absolutely right. I went with the Automatic installer on my Raspberry Pi 3
              Worked perfectly, and the directions are damn good
              • I Offline
                infamoustiggr
                I know, but I’ve got a Pi 1 model b. Unfortunately the easy install option is unavailable…
                I’ve got as far as the npm install, but it’s throwing up lots of error in a log file… Any hints?
                  @infamoustiggr
                  This is from the main installation page at https://github.com/MichMich/MagicMirror#manual-installation
                  Raspberry Pi Support
                  Electron, the app wrapper around MagicMirror², only supports the Raspberry Pi 2 & 3. The Raspberry Pi 1 is currently not supported. If you want to run this on a Raspberry Pi 1, use the server only feature and setup a fullscreen browser yourself.
                  Server Only:
                  In some cases, you want to start the application without an actual app window. In this case, execute the following command from the MagicMirror folder: node serveronly. This will start the server, after which you can open the application in your browser of choice.
                  I hope this helps
                  I 1 Reply Last reply Reply Quote 1
                  • I Offline
                    infamoustiggr @Mykle1
                    @Mykle1 ho there! I had read this bit too, but, being as I am to programming what a brick is to top flight springboard diving, I’m getting stuck on what parts of the instructions apply to me and which don’t. For example, the npm install comes up with a horrific number of errors, but I don’t know if I actually need it…
                    Once I’ve got this working I’ll write it up… I’m sure there’s a while bunch of people who bought the Pi 1 b and have since upgraded!
                    • AlvingerA Offline
                      Alvinger
                      Hi all,
                      I’m running my mirror on an original Pi B 256MB with no issues at all!
                      The Raspbian version I use is DietPi which is really great on a 256MB Pi. Note that the standard user in DietPi is “root” rather than “pi”. If you use standard Raspbian just replace all occurences of “root” with “pi” in the scripts below.
                      As the documentation states you start off with installing the Server Only option. If I remember correctly I had to manually install many of the node module dependencies as they weren’t installed correctly otherwise
                      I use matchbox as the window manager because it suited my needs best. It uses less resources which again is great for a 256MB Pi.
                      I’m using systemd scripts rather than pm2 as I think they work better. My scripts:
                      magicmirror.service:
                      [Unit]
                      Description=Node.js Magic Mirror Server
                      [Service]
                      ExecStart=/usr/bin/node /root/MagicMirror/serveronly/index.js
                      WorkingDirectory=/root/MagicMirror
                      Restart=always
                      RestartSec=20
                      StandardOutput=syslog
                      StandardError=syslog
                      SyslogIdentifier=nodejs-magicmirror
                      Environment=NODE_ENV=production PORT=1337
                      [Install]
                      WantedBy=multi-user.target
                      matchbox.service:
                      [Unit]
                      Description=X11
                      After=X.service
                      [Service]
                      Environment=DISPLAY=:0.0
                      ExecStart=/usr/bin/matchbox-window-manager -use_titlebar no -use_cursor no
                      User=root
                      Restart=on-failure
                      [Install]
                      Kioskbrowser.service:
                      [Unit]
                      Description=Kiosk Browser
                      After=matchbox.service magicmirror.service
                      Requires=magicmirror.service
                      [Service]
                      User=root
                      # Don't activate screensaver
                      ExecStartPre=/usr/bin/xset s off
                      # Disable DPMS (Energy Star) features
                      ExecStartPre=/usr/bin/xset -dpms
                      # Don't blank the video device
                      ExecStartPre=/usr/bin/xset s noblank
                      ExecStart=/root/kioskbrowser http://localhost
                      Restart=on-failure
                      [Install]
                      Note that the kioskbrowser service relies on a user script called /root/kioskbrowser. This script has some extra logic to avoid the initial white screen when midori has loaded but not fetched any magic mirror content. The script perform a curl call to see if the magic mirror module is responding. If not it waits for a few seconds and then tries again. Once the magic mirror responds it starts midori in fullscreen mode.
                      /root/kioskbrowser:
                      #!/bin/bash
                      status=1
                      url="$1"
                      wait="10s"
                      tries=0
                      # URL must be first argument
                      if [ -z "$url" ]; then
                        exit 1
                      fi
                      # Make sure that the url is reachable
                      while [ $status -ne 0 ]; do
                        let tries++
                        curl --fail --progress-bar -o /dev/null --url "$url"
                        status=$?
                        if (($tries > 10)); then
                          wait="30s"
                        fi
                        if (($tries > 20)); then
                        wait="5m"
                        fi
                        if (($tries > 30)); then
                        echo "$0: Can't load URL $url"
                          exit 2
                        fi
                        sleep "$wait"
                      done
                      # Start browser in fullscreen mode
                      /usr/bin/midori -e Fullscreen -a "$url"
                      Hope this helps.
                      • I Offline
                        infamoustiggr
                        Hi Alvinger,
                        That sounds exactly what I need thanks, with the only problem being that, being a complete learner, I don’t know what to do with it…
                        Do I need to put the scripts into a particular file or just write them into the command line itself?
                        On the whole I’ve managed most projects independently thanks to the mighty google and suitable search terms, got my media centre and a pi in my van as a music/film hub, but this is the first thing that’s been a bit more complicated and I’ve failed miserably to this point…
                        I’ve been trying to learn this sort of thing for years and just never seem to have the time. I’m a physio by trade, so I don’t even have something close to this as my day job.
                        Thanks for your patience!
                        Nick
                        AlvingerA 1 Reply Last reply Reply Quote 0
