    MMM-ProfileSwitcher, A Profile/User/Layout Switching Module
    userswitchprofilelayoutmodule
    91 Posts 21 Posters 162.4k Views 23 Watching
    • SnilleS
      Snille Module Developer @tosti007
      @tosti007 Hehe, I just edited my post when you replied. Found the title thing… Sorry for not reading… :)
      I have my language like so:
      	ipWhitelist: [
      		"127.0.0.1",
      		"::ffff:127.0.0.1",
      		"::1",
      		"::ffff:10.0.0.1/120"
      	language: "sv",
      Seems to work with the clock at least (get the swedish names of the days. :)…
      I just saw a “leave message” in german… I have to try to grab a screenshot…
      tosti007T 1 Reply Last reply
      • tosti007T
        tosti007 Module Developer @Snille
        @Snille ah yea I don’t have Swedish translations (I only speak English, German and Dutch and that’s more than enough imo xD) and apparently it chooses German then instead.
        Try setting includeEveryoneMessages to false in the config. It shouldn’t show up then but if it doesn’t let me know.
        If there is anything don’t hesitate to contact me!
        ProfileSwitcher, TouchNotifications
        SnilleS 1 Reply Last reply
        • SnilleS
          @tosti007 Here you go:
          sv.json
            "leave": "Ses snart %profile%!",
            "enter": "Hej %profile%, trevligt att ses igen!",
            "title": "Användarprofil"
          • tosti007T
            @Snille Thank you very much :) was about to ask :D
            • tosti007T
              tosti007 Module Developer @tosti007
              @tosti007 said in MMM-ProfileSwitcher, A Profile/User/Layout Switching Module:
              I will update the line numbers aswell, thank you! I will let you know when I changed it.
              @Snille Updated :) You have to remove only a few lines more and then it should work like before! Also added your translations :) thank you once more
              • tosti007T
                @All Hello everybody! Version 2 is out now :D You can set a timer to switch from one profile to another after a certain amount of time! For an explanation on how to configure them check the README. After a feature request of @shashank.
                  Mar
                  So i’ve added the MMM-ProfileSwitcher to the config file along with “classes: ‘default xyz’” etc to each module under the config file. With one module having only a class of “PAGE2”.
                  Using MMM-Buttons i have it successfully pushing a notification saying PAGE2 but nothing is happening on my MM, also all the modules are showing up? When the notification is pushed in the pm2 logs i see all the modules receiving the notification but i dont ever see profileswitcher in that list.
                  I honestly dont know what im doing wrong, the profileswitcher is loading according to the pm2 logs (with an error) but for instance one of my modules I have a unique class set so it should only be visible for that profile but it still shows up when the mirror loads on the default page.
                  edit:
                  Noticed this error on pm2 logs x
                  0|mm       | ** Message: console message: http://localhost:8080/modules/MMM-ProfileSwitcher//MMM-ProfileSwitcher.js @87: SyntaxError: Unexpected token '>'
                  Line reads:
                  self.config.ignoreModules.some((m) => classes.includes(m)) || // Should this module be ignored?
                  Also same at line 204/108 wondering if it should be an =, >=, or perhaps a < =? It also doesnt seem to like line 205 return statement (but im not sure what this one means).
                    shashank @tosti007
                    @tosti007 Hi, Thanks a Lot, Profile switch timer is working fine, tested the same.
                    • tosti007T
                      tosti007 Module Developer @Mar
                      @Mar After a helpfull pull request by @Jopyth this line got removed. Try pulling the new changes and let me know if still gives problems! Thank you for letting me know that bug.
                      @All The module uses lockstrings now! This due to some problems in combination with other modules. Give the README configurables a look if you want to disable this.
                      Edit: Ugh I just noticed I made a terrible mistake in that line. the => should have been >==. Thanks again!
                      Edit 2: Double ugh, read it again and it was right.
                      M 1 Reply Last reply
                        Mar @tosti007
                        @tosti007 Thanks for the updates, still looks like lines 214 & 218 contain the “=>” were these supposed to be switched to >== also?
                        So just getting those error so far, but still no luck on the switcher. Im really not sure what I’m doing wrong. I’ve simplified my config file to the following to try make it load the default profile and just switch to ‘PAGE2’. But when the MM loads I get both the clock and weather still on the screen.
                                                module: 'alert',
                                                module: "updatenotification",
                                                position: "top_bar"
                                                module: 'MMM-ProfileSwitcher',
                                                module: 'MMM-Buttons',
                                                buttons: [
        pin: 5,
        shortPress: {
        notification: "PROFILE_SWITCH",
        payload: {action: "PAGE2"}
                                                module: 'clock',
                                                classes: 'default',
                                                position: 'top_left',
                                                module: 'currentweather',
                                                classes: 'PAGE2',
                                                position: 'top_right',
                                                        locationID: '...',
                                                        appid: '...'
                        and when i press the button pm2 logs only shows this but nothing happens on the screen.
                        0|mm       | ** Message: console message: [native code] @0: clock received a module notification: PROFILE_SWITCH from sender: MMM-Buttons
                        edit: On the main HDMI cable monitor the mirror is showing both modules, but if i go via chrome on my laptop it only shows the clock (but still doesnt switch when pressing the button). The inspector in Chrome shows that its hiding non-default modules…seems like Midori doesnt get to this (but I have no way to check)
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @Mar
                          @Mar => are big arrow functions from ecmascript6, which is the newest standard of javascript
                            Mar @strawberry 3.141
                            @strawberry-3.141 Thanks, I never seem to have had any issues with these before but only on my pi zero. Loading up the latest profile switcher (using my simple 2 module) i get this error relating to that line
                            0|mm       | ** Message: console message: http://localhost:8080/modules/MMM-ProfileSwitcher//MMM-ProfileSwitcher.js @214: SyntaxError: Unexpected token '>'
                            But it seems to work via a remote browser (i.e chrome but switching doesnt work) and not the pi’s midori which still shows both modules.
                            • strawberry 3.141S
                              @Mar for me electron is supporting all those es6 features, just heard of that some users had problems with some of my modules with the midori browser
                              M 2 Replies Last reply
                                @strawberry-3.141 Yeah seems to be a midori thing, unfortunately I’m using a pi zero so need to use midori as it runs pretty amazing with the pi. Electron really slows it down.
                                Wondering if there is a way around this at all? Maybe breaking out the arrow functions to normal one might work?
                                  @strawberry-3.141
                                  So ive broken out those functions to the following and now get no errors:
                                  *OLD*
                                                  value = value.map((x) => {
                                                      return x === true ? translated : x;
                                  *NEW*
                                                  value = value.map(
                                                          function(x){
        return x === true ? translated :x;
                                  *OLD*
                                                  classes.split(" ").forEach((key) => {
                                                      if (result[key] === undefined) {
                                                          result[key] = [];
                                                      result[key] = result[key].concat(value);
                                  *NEW*
                                  					function(key) {
                                  	                        result[key] = [];
                                  Now the only error i am getting is on line 89
                                  TypeError: undefined is not a function (evaluating 'classes.includes(self.current_profile)')
                                  But im not sure how to fix this one. And this is the function that decides what to show which could be where Midori cannot parse it properly.
                                  • strawberry 3.141S
                                    @Mar that is also an es6 feature try classes.indexOf(self.current_profile) !== -1
                                      @strawberry-3.141 Thanks, I couldnt figure that one out.
                                      return classes.indexOf(self.current_profile) !== -1;
                                      Along with the changes in the previous post I’ve have fully loaded ProfileSwitcher Midori without any errors. It also is showing the correct modules on load (classes = default).
                                      Thanks for the help through this @strawberry-3-141
                                      Managed to figure this all out so thanks to everyone!
                                      • tosti007T
                                        @strawberry-3-141 thank you for helping @Mar
                                        @All @Mar I didn’t know that that browser doesn’t support those features. I will rewite those parts so then it should work out of the box.
                                        • tosti007T
                                          @all I pushed a small update so that older browers should also be able to use this module.
                                          @Mar They are the same changes that you made.
                                            Mar @tosti007
                                            @tosti007 Thanks for updating your module so quickly! and obviously thanks for taking the time to respond and maintain.
                                            • 1 / 5
