    [MMM-Buttons] Connect multiple buttons to send configurable notifications
    40 Posts 15 Posters 36.3k Views 14 Watching
    • istepgueuI Offline
      istepgueu
      Hi @Jopyth !
      Thanks for your module.
      I would like to use an on / off button instead of a push button
      for my garage door project (https://forum.magicmirror.builders/topic/1620/garage-door-detectors)
      Is there a way to send a notification on “button_up” and an other notification on “Button_down” ?
      Thank you very much ;-)
        istepgueu
        Does anyone know how to read the initial value of a button (GPIO) before it is run ?
        Thanks.
          Mar
          @Jopyth Moved my post here out from another thread.
          I am having one more issue though. Using a python test program i can see every single instance of my button press is registered instantly. But in the mirror it seems MMM-Buttons doesnt register pushes unless sometimes I double or triple click…then sometimes the button registers 5-6 times. I’m not really sure how to debug this sort of thing.
          Also would it be right to assume the pull up/down resistors were not enabled with MMM-Buttons?
          istepgueuI 2 Replies Last reply Reply Quote 0
            istepgueu @Mar
            @Mar all is here https://forum.magicmirror.builders/topic/211/button
              istepgueu @Mar
              @Mar i have same problem. I run my little script button.py before start MM and its solve the problem
                Mar @istepgueu
                @istepgueu Ive taken your button.py program and modified it for me two buttons 5/6. And while the program reads my button presses perfectly, MM-Buttons doesnt at all. I pretty much have to double click each time to make a button register. It switches my profiles just fine … but just takes lots of clicks to register.
                import RPi.GPIO as GPIO
                import time
                GPIO.setmode(GPIO.BCM)
                GPIO.setup(5, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                GPIO.setup(6, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                tries = 0
                while (tries < 200000):
                    if GPIO.input(6):
                        print("Open 6")
                    else:
                        print("Close 6")
                    if GPIO.input(5):
                        print("Open 5")
                    else:
                        print ("Close 5")
                    time.sleep(0.5)
                    tries = tries + 1
                  Mar @istepgueu
                  @istepgueu Will take a look through this now, but i already have a 1k resistor between pins 5/6 and the respective button. Hopefully something else comes up here.
                  Yes my problem seems a bit opposite of what was posted in your link. I dont have any erroneous button presses, it just takes a few clicks until MMM-Buttons registers the click. You button.py registers every click instantly. So must be something in the buttons code?
                    Jopyth Moderator
                    @Mar @istepgueu The library (onoff) I am currently using does not directly allow configuring pull up and pull down resistors, and I was not able to make it consistently work (see Readme).
                    Therefore I myself made use of the “right” pins for my setup, as the readme says:
                    The defaults can be seen in Table 6-31 on pages 102 and 103 of the BCM2835 ARM Peripherals documentation.
                    There I simply used buttons with the correct default pull-up/pull-down resistor configuration (second column of that table), and I wanted a few pins close together on the board, so I chose GPIO 22,23,24 and 25 (connected 4 buttons), since they all have the default of a low input.
                      Mar @Jopyth
                      @Jopyth Thanks for the response, and that seems to make complete sense. I missed that part in the documentation.
                      Though upon trying PINS 22/23 i am still getting the same result. The button.py program detects each individual click properly, but in the MM I have to double (sometimes triple) click the button so that it registers. I can see it registers as it shows up in the pm2 logs and my profile changes.
                      Im not sure if its an issue with the buttons as they are a standard 4 pin button and the test script works fine with them?
                        Jopyth Moderator @Mar
                        @Mar Well its not, as if it were documented anywhere in my readme. :( Should probably add this somewhere.
                        How long are you pressing the button? For a very short time? Note, that if the press is longer than 500ms it will not be registered as a (short) press (it is the maxShortPressTime and can be configured).
                        If this is not the case, I am sorry, but I have no real idea how to fix it, without having the same situation on my Pi.
                        M 3 Replies Last reply Reply Quote 1
                        • 1 / 4
