    [MMM-Buttons] Connect multiple buttons to send configurable notifications
    40 Posts 15 Posters 37.6k Views 14 Watching
      Jopyth Moderator
      Description:
      This is a module for Magic Mirror² to act based on button presses via GPIO.
      It is basically a generalized version of the Button module, original idea comes from @PtrBld.
      It is capable of connecting multiple buttons at once, which can be individually configured.
      However it only sends out notifications to other modules.
      For example this can be used to send notifications to the following modules:
      • Remote Control
      • Profile Switcher
      Download:
      [card:Jopyth/MMM-Buttons]
      FAQ
      Error on npm install: An unhandled error occurred inside electron-rebuild. Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
      Possible Solution: Upgrade your MagicMirror 2.1.0 or higher.
      Changelog
      [1.0.0] - 2017-01-28
      Initial release of the Buttons module.
        Burner911
        This sounds awesome! Do you think there is a relatively easy way to output from the GPIO instead? I would like to turn my TV off using a transistor being it does not support HDMI-CEC like a monitor does. I’m thinking this might be best discussed with regards to MMM-Remote-Control.
        • tosti007T Offline
          tosti007 Module Developer
          Nice! I think many people will be able to use this for their mirror
          If there is anything don't hesitate to contact me!
          ProfileSwitcher, TouchNotifications
          • istepgueuI Offline
            istepgueu
            Hi @Jopyth !
            Thanks for your module.
            I would like to use an on / off button instead of a push button
            for my garage door project (https://forum.magicmirror.builders/topic/1620/garage-door-detectors)
            Is there a way to send a notification on “button_up” and an other notification on “Button_down” ?
            Thank you very much ;-)
              istepgueu
              Does anyone know how to read the initial value of a button (GPIO) before it is run ?
              Thanks.
                Mar
                @Jopyth Moved my post here out from another thread.
                I am having one more issue though. Using a python test program i can see every single instance of my button press is registered instantly. But in the mirror it seems MMM-Buttons doesnt register pushes unless sometimes I double or triple click…then sometimes the button registers 5-6 times. I’m not really sure how to debug this sort of thing.
                Also would it be right to assume the pull up/down resistors were not enabled with MMM-Buttons?
                istepgueuI 2 Replies Last reply Reply Quote 0
                  istepgueu @Mar
                  @Mar all is here https://forum.magicmirror.builders/topic/211/button
                    istepgueu @Mar
                    @Mar i have same problem. I run my little script button.py before start MM and its solve the problem
                      Mar @istepgueu
                      @istepgueu Ive taken your button.py program and modified it for me two buttons 5/6. And while the program reads my button presses perfectly, MM-Buttons doesnt at all. I pretty much have to double click each time to make a button register. It switches my profiles just fine … but just takes lots of clicks to register.
                      import RPi.GPIO as GPIO
                      import time
                      GPIO.setmode(GPIO.BCM)
                      GPIO.setup(5, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                      GPIO.setup(6, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                      tries = 0
                      while (tries < 200000):
                          if GPIO.input(6):
                              print("Open 6")
                          else:
                              print("Close 6")
                          if GPIO.input(5):
                              print("Open 5")
                          else:
                              print ("Close 5")
                          time.sleep(0.5)
                          tries = tries + 1
                        Mar @istepgueu
                        @istepgueu Will take a look through this now, but i already have a 1k resistor between pins 5/6 and the respective button. Hopefully something else comes up here.
                        Yes my problem seems a bit opposite of what was posted in your link. I dont have any erroneous button presses, it just takes a few clicks until MMM-Buttons registers the click. You button.py registers every click instantly. So must be something in the buttons code?
                          Jopyth Moderator
                          @Mar @istepgueu The library (onoff) I am currently using does not directly allow configuring pull up and pull down resistors, and I was not able to make it consistently work (see Readme).
                          Therefore I myself made use of the “right” pins for my setup, as the readme says:
                          The defaults can be seen in Table 6-31 on pages 102 and 103 of the BCM2835 ARM Peripherals documentation.
                          There I simply used buttons with the correct default pull-up/pull-down resistor configuration (second column of that table), and I wanted a few pins close together on the board, so I chose GPIO 22,23,24 and 25 (connected 4 buttons), since they all have the default of a low input.
                            Mar @Jopyth
                            @Jopyth Thanks for the response, and that seems to make complete sense. I missed that part in the documentation.
                            Though upon trying PINS 22/23 i am still getting the same result. The button.py program detects each individual click properly, but in the MM I have to double (sometimes triple) click the button so that it registers. I can see it registers as it shows up in the pm2 logs and my profile changes.
                            Im not sure if its an issue with the buttons as they are a standard 4 pin button and the test script works fine with them?
                              Jopyth Moderator @Mar
                              @Mar Well its not, as if it were documented anywhere in my readme. :( Should probably add this somewhere.
                              How long are you pressing the button? For a very short time? Note, that if the press is longer than 500ms it will not be registered as a (short) press (it is the maxShortPressTime and can be configured).
                              If this is not the case, I am sorry, but I have no real idea how to fix it, without having the same situation on my Pi.
                              M 3 Replies Last reply Reply Quote 1
                                Mar @Jopyth
                                @Jopyth I thought this also, and set the short time from 0-1000ms and still will only register the second of a double click.
                                Its very consistent though, i can get it to work 100% of the time with a double click like opening a folder on the computer. one click doesnt do anything, and I don’t believe the longPress worked at all (But i wasnt using it so not that bothered with it).
                                Maybe its just the buttons…i just dont have anything else around that i could use to test as a button.
                                  Mar @Jopyth
                                  @Jopyth Just tested with buttons ripped out from an old monitor and same issue, needed to double click. I suppose i will slowly go through the code and try break it down and see. any advice on which functions to start with?
                                    Mar @Jopyth
                                    @Jopyth Fixed!! I switched the 1 and the 0 in the watchHandler function of node_helper.js and solved the issue. Must have been backwards with how the button was being interpreted vs set up?
                                    Put the 0 first, then 1.
                                    Now the double click makes sense, the time between the clicks seems to have been what was counted as a valid min press time.
                                      Mar
                                      @Jopyth Anyway to use one button to switch between profiles? Trying to use profile switches classes and creating the same button on different profiles (classes) but it always runs both buttons so take me back to the default page.
                                        @Mar Glad you got it work. :) Did you switch back to the default (regarding the 0 and 1)? Or is it now different than in the main code? Not yet possible to switch between multiple profiles. Could maybe be implemented as an array of notification definitions, instead of a single notification definition and then it cycles through these notifications on each press?
                                          Mar @Jopyth
                                          @Jopyth No i had to switch the 1 and the 0 to make it work (0 first, then 1) so my code does differ slightly unfortunately. Suppose I’ll have to remember to manually make the change on updates unless it can be made a config option.
                                          That could be a good option. We’d need a way for profile switcher to send over all unique profiles which would make it easy to do, rather than scrape the config file for “classes”.
                                          edit: Though I suppose thinking about this not relying on another module would be much quicker fix.
                                            A Former User
                                            What if I want to send an alert show display message when the GPIO port is ON? I mean, is not like a switch that closes the GPIO port, is when you programatically send an outoput GPIO signal to close (lets say a relay). Is there any changes necessary? I can´t make it happen.
                                                     module: 'MMM-Buttons',
                                                    buttons: [
                                                             pin: 17,
                                                            longPress: {
        title: "Rele longpress",
        message: 'El rele esta siendo pulsado largo',
        imageFA: 'power-off',
        notification: 'SHOW_ALERT',
        payload: {
        type: 'notification',
        title: 'Alerta rele pulsado largo'
        shortPress:  {
        title: "Rele shortress",
        message: 'El rele esta siendo pulsado corto',
        imageFA: 'power-on',
        payload: {
                                                            } //del config
