    [MMM-Buttons] Connect multiple buttons to send configurable notifications
    40 Posts 15 Posters 33.5k Views 14 Watching
      Jopyth Moderator
      Description:
      This is a module for Magic Mirror² to act based on button presses via GPIO.
      It is basically a generalized version of the Button module, original idea comes from @PtrBld.
      It is capable of connecting multiple buttons at once, which can be individually configured.
      However it only sends out notifications to other modules.
      For example this can be used to send notifications to the following modules:
      • Remote Control
      • Profile Switcher
      Download:
      [card:Jopyth/MMM-Buttons]
      FAQ
      Error on npm install: An unhandled error occurred inside electron-rebuild. Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
      Possible Solution: Upgrade your MagicMirror 2.1.0 or higher.
      Changelog
      [1.0.0] - 2017-01-28
      Initial release of the Buttons module.
        Burner911
        This sounds awesome! Do you think there is a relatively easy way to output from the GPIO instead? I would like to turn my TV off using a transistor being it does not support HDMI-CEC like a monitor does. I’m thinking this might be best discussed with regards to MMM-Remote-Control.
        • tosti007T Offline
          tosti007 Module Developer
          Nice! I think many people will be able to use this for their mirror
          If there is anything don't hesitate to contact me!
          ProfileSwitcher, TouchNotifications
          • istepgueuI Offline
            istepgueu
            Hi @Jopyth !
            Thanks for your module.
            I would like to use an on / off button instead of a push button
            for my garage door project (https://forum.magicmirror.builders/topic/1620/garage-door-detectors)
            Is there a way to send a notification on “button_up” and an other notification on “Button_down” ?
            Thank you very much ;-)
              istepgueu
              Does anyone know how to read the initial value of a button (GPIO) before it is run ?
              Thanks.
                Mar
                @Jopyth Moved my post here out from another thread.
                I am having one more issue though. Using a python test program i can see every single instance of my button press is registered instantly. But in the mirror it seems MMM-Buttons doesnt register pushes unless sometimes I double or triple click…then sometimes the button registers 5-6 times. I’m not really sure how to debug this sort of thing.
                Also would it be right to assume the pull up/down resistors were not enabled with MMM-Buttons?
                istepgueuI 2 Replies Last reply Reply Quote 0
                  istepgueu @Mar
                  @Mar all is here https://forum.magicmirror.builders/topic/211/button
                    istepgueu @Mar
                    @Mar i have same problem. I run my little script button.py before start MM and its solve the problem
                      Mar @istepgueu
                      @istepgueu Ive taken your button.py program and modified it for me two buttons 5/6. And while the program reads my button presses perfectly, MM-Buttons doesnt at all. I pretty much have to double click each time to make a button register. It switches my profiles just fine … but just takes lots of clicks to register.
                      import RPi.GPIO as GPIO
                      import time
                      GPIO.setmode(GPIO.BCM)
                      GPIO.setup(5, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                      GPIO.setup(6, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                      tries = 0
                      while (tries < 200000):
                          if GPIO.input(6):
                              print("Open 6")
                          else:
                              print("Close 6")
                          if GPIO.input(5):
                              print("Open 5")
                          else:
                              print ("Close 5")
                          time.sleep(0.5)
                          tries = tries + 1
                        Mar @istepgueu
                        @istepgueu Will take a look through this now, but i already have a 1k resistor between pins 5/6 and the respective button. Hopefully something else comes up here.
                        Yes my problem seems a bit opposite of what was posted in your link. I dont have any erroneous button presses, it just takes a few clicks until MMM-Buttons registers the click. You button.py registers every click instantly. So must be something in the buttons code?
                        • 1 / 4
