    [MMM-Buttons] Connect multiple buttons to send configurable notifications
    40 Posts 15 Posters 39.4k Views 14 Watching
    • I Offline
      istepgueu @Mar
      @Mar i have same problem. I run my little script button.py before start MM and its solve the problem
        Mar @istepgueu
        @istepgueu Ive taken your button.py program and modified it for me two buttons 5/6. And while the program reads my button presses perfectly, MM-Buttons doesnt at all. I pretty much have to double click each time to make a button register. It switches my profiles just fine … but just takes lots of clicks to register.
        import RPi.GPIO as GPIO
        import time
        GPIO.setmode(GPIO.BCM)
        GPIO.setup(5, GPIO.IN, pull_up_down=GPIO.PUD_UP)
        GPIO.setup(6, GPIO.IN, pull_up_down=GPIO.PUD_UP)
        tries = 0
        while (tries < 200000):
            if GPIO.input(6):
                print("Open 6")
            else:
                print("Close 6")
            if GPIO.input(5):
                print("Open 5")
            else:
                print ("Close 5")
            time.sleep(0.5)
            tries = tries + 1
          Mar @istepgueu
          @istepgueu Will take a look through this now, but i already have a 1k resistor between pins 5/6 and the respective button. Hopefully something else comes up here.
          Yes my problem seems a bit opposite of what was posted in your link. I dont have any erroneous button presses, it just takes a few clicks until MMM-Buttons registers the click. You button.py registers every click instantly. So must be something in the buttons code?
            Jopyth Moderator
            @Mar @istepgueu The library (onoff) I am currently using does not directly allow configuring pull up and pull down resistors, and I was not able to make it consistently work (see Readme).
            Therefore I myself made use of the “right” pins for my setup, as the readme says:
            The defaults can be seen in Table 6-31 on pages 102 and 103 of the BCM2835 ARM Peripherals documentation.
            There I simply used buttons with the correct default pull-up/pull-down resistor configuration (second column of that table), and I wanted a few pins close together on the board, so I chose GPIO 22,23,24 and 25 (connected 4 buttons), since they all have the default of a low input.
              Mar @Jopyth
              @Jopyth Thanks for the response, and that seems to make complete sense. I missed that part in the documentation.
              Though upon trying PINS 22/23 i am still getting the same result. The button.py program detects each individual click properly, but in the MM I have to double (sometimes triple) click the button so that it registers. I can see it registers as it shows up in the pm2 logs and my profile changes.
              Im not sure if its an issue with the buttons as they are a standard 4 pin button and the test script works fine with them?
                Jopyth Moderator @Mar
                @Mar Well its not, as if it were documented anywhere in my readme. :( Should probably add this somewhere.
                How long are you pressing the button? For a very short time? Note, that if the press is longer than 500ms it will not be registered as a (short) press (it is the maxShortPressTime and can be configured).
                If this is not the case, I am sorry, but I have no real idea how to fix it, without having the same situation on my Pi.
                M 3 Replies Last reply Reply Quote 1
                  Mar @Jopyth
                  @Jopyth I thought this also, and set the short time from 0-1000ms and still will only register the second of a double click.
                  Its very consistent though, i can get it to work 100% of the time with a double click like opening a folder on the computer. one click doesnt do anything, and I don’t believe the longPress worked at all (But i wasnt using it so not that bothered with it).
                  Maybe its just the buttons…i just dont have anything else around that i could use to test as a button.
                    Mar @Jopyth
                    @Jopyth Just tested with buttons ripped out from an old monitor and same issue, needed to double click. I suppose i will slowly go through the code and try break it down and see. any advice on which functions to start with?
                      Mar @Jopyth
                      @Jopyth Fixed!! I switched the 1 and the 0 in the watchHandler function of node_helper.js and solved the issue. Must have been backwards with how the button was being interpreted vs set up?
                      Put the 0 first, then 1.
                      Now the double click makes sense, the time between the clicks seems to have been what was counted as a valid min press time.
                        Mar
                        @Jopyth Anyway to use one button to switch between profiles? Trying to use profile switches classes and creating the same button on different profiles (classes) but it always runs both buttons so take me back to the default page.
                          @Mar Glad you got it work. :) Did you switch back to the default (regarding the 0 and 1)? Or is it now different than in the main code? Not yet possible to switch between multiple profiles. Could maybe be implemented as an array of notification definitions, instead of a single notification definition and then it cycles through these notifications on each press?
                            Mar @Jopyth
                            @Jopyth No i had to switch the 1 and the 0 to make it work (0 first, then 1) so my code does differ slightly unfortunately. Suppose I’ll have to remember to manually make the change on updates unless it can be made a config option.
                            That could be a good option. We’d need a way for profile switcher to send over all unique profiles which would make it easy to do, rather than scrape the config file for “classes”.
                            edit: Though I suppose thinking about this not relying on another module would be much quicker fix.
                              [[global:former-user]]
                              What if I want to send an alert show display message when the GPIO port is ON? I mean, is not like a switch that closes the GPIO port, is when you programatically send an outoput GPIO signal to close (lets say a relay). Is there any changes necessary? I can´t make it happen.
                                       module: 'MMM-Buttons',
                                      buttons: [
                                               pin: 17,
                                              longPress: {
                                                              title: "Rele longpress",
                                                              message: 'El rele esta siendo pulsado largo',
                                                              imageFA: 'power-off',
                                                              notification: 'SHOW_ALERT',
                                                              payload: {
        type: 'notification',
        title: 'Alerta rele pulsado largo'
                                                      shortPress:  {
                                                              title: "Rele shortress",
                                                              message: 'El rele esta siendo pulsado corto',
                                                             imageFA: 'power-on',
                                                       payload: {
                                              } //del config
                                PointPubMedia
                                Anyone have an example of a switching profile using Buttons + ProfileSwitcher ?
                                  Mar @PointPubMedia
                                  @PointPubMedia
                                                          module: 'MMM-ProfileSwitcher',
        includeEveryoneToDefault: true,
        ignoreModules: ["alert", "updatenotification"],
        enterMessages: false,
        leaveMessages: false,
        defaultTime: 15000,
        timers: {
        "PAGE2":{profile:"default"}, //Switch to defaultClass after defaultTime
                                                          minShortPressTime: 0,
                                                          maxShortPressTime: 1000,
                                                          minLongPressTime: 3000,
                                                          buttons: [
        pin:23,
        longPress: undefined,
        shortPress: {
        notification: "CURRENT_PROFILE",
        payload: "PAGE2"
        pin: 22,
        shortPress: {
        payload: "default"
                                    B4rth
                                    can this module be used to send notification to the newsfeed module?
                                    I can’t get it to work, not throuht sending it directly nether over the remote-module.
                                    Have anyone have done it and can help me?
                                      Jopyth Moderator @B4rth
                                      @B4rth Please note that a notification never has a dedicated receiver. It is always a broadcast to all other modules. But sending notifications should definitely work with the module. Is your button working? If you are struggling with the correct URL for sending notifications, you can use this fiddle to build the correct URL.
                                      The below config should be a simple example for showing an alert (it sends a notification to all modules and the alert module reacts to it):
                                              buttons: [
                                                      pin: 25,
                                                      longPress: {
                                                          notification: "SHOW_ALERT",
                                                          payload: {"title": "Hello World", "message": "Long Press!"}
                                                      shortPress: {
                                                          payload: {"title": "Hello World", "message": "Short Press!"}
                                      Make sure to check that you are using the correct pin number and change the notification config, if you want another module to react.
                                        PointPubMedia
                                        Hey guys…
                                        Is it me or having this module + ProfileSwitcher + Facial are not working well together.
                                        I have no issue using the buttons + ProfileSwitcher as I can toggle between profile! Facial recognize me but switch to nothing…
                                          Jopyth Moderator @PointPubMedia
                                          @PointPubMedia Did you check out this section? There are some changes needed to make both work together smoothly.
                                            RickyTerzis
                                            Hi…i am a new user here. In my case sing a python test program i can see every single instance of my button press is registered instantly. But in the mirror it seems MMM-Buttons doesnt register pushes unless sometimes I double or triple click.
