    Adding Modules
    29 Posts 3 Posters 16.6k Views 3 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @johnnyboy
      @johnnyboy if you have done npm install request moment than you can ignore the warnings about the missing file you’re good to continue, if you have done npm install --productive nothing happened because he cant read data out of an file that doesnt exist.
      johnnyboyJ 1 Reply Last reply
      • johnnyboyJ
        johnnyboy @strawberry 3.141
        • strawberry 3.141S
          @johnnyboy in the config there is a modules: [] section put it right before the closing ]don’t forget to add a comma in front if there is none after the } from the last module in the section
          • johnnyboyJ
            • strawberry 3.141S
              @johnnyboy in your magiccmirror directory you have the config directory and in their your config.js
              • johnnyboyJ
                • johnnyboyJ
                  johnnyboy @johnnyboy
                  • johnnyboyJ
                    strawberry 3.141S johnnyboyJ 2 Replies Last reply
                    • strawberry 3.141S
                      @johnnyboy there is
                        //all your configure modules
                        //put the module at the end
                      • johnnyboyJ
                        • johnnyboyJ
                          • johnnyboyJ
                            • strawberry 3.141S
                              @johnnyboy you have to fill in your apikey
                              • johnnyboyJ
                                • strawberry 3.141S
                                  @johnnyboy https://www.wunderground.com/weather/api/d/pricing
                                  • johnnyboyJ
                                    johnnyboyJ Mykle1M 2 Replies Last reply
                                    • johnnyboyJ
                                      Mykle1M 1 Reply Last reply
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @johnnyboy
                                        @johnnyboy said in Adding Modules:
                                        *** Note to self *** Must remember to check first whether a module requires a monthly fee to be paid before use.
                                        Must go and remove that module from my config now…
                                        You can get a free API key there. Put that module back in your config, and smile. :smile:
                                        • johnnyboyJ
                                          johnnyboy @Mykle1
                                          • Mykle1M
                                            Is this module US only?
                                            No, there’s weather all over the planet. :wink:
