    Adding Modules
    29 Posts 3 Posters 15.8k Views 3 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @johnnyboy
      @johnnyboy only the part that i posted
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @strawberry 3.141
          @johnnyboy if you have done npm install request moment than you can ignore the warnings about the missing file you’re good to continue, if you have done npm install --productive nothing happened because he cant read data out of an file that doesnt exist.
              @johnnyboy in the config there is a modules: [] section put it right before the closing ]don’t forget to add a comma in front if there is none after the } from the last module in the section
              johnnyboyJ 1 Reply Last reply Reply Quote 1
                  @johnnyboy in your magiccmirror directory you have the config directory and in their your config.js
                      johnnyboy @johnnyboy
                        strawberry 3.141S johnnyboyJ 2 Replies Last reply Reply Quote 0
                          @johnnyboy there is
                            //all your configure modules
                            //put the module at the end
                                  @johnnyboy you have to fill in your apikey
                                      @johnnyboy https://www.wunderground.com/weather/api/d/pricing
                                        johnnyboyJ Mykle1M 2 Replies Last reply Reply Quote 0
                                            Mykle1 Project Sponsor Module Developer @johnnyboy
                                            @johnnyboy said in Adding Modules:
                                            *** Note to self *** Must remember to check first whether a module requires a monthly fee to be paid before use.
                                            Must go and remove that module from my config now…
                                            You can get a free API key there. Put that module back in your config, and smile. :smile:
