    Adding Modules
    29 Posts 3 Posters 16.2k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @johnnyboy
      @johnnyboy said in Adding Modules:
      First off, a massive shout out to Mykle1 for helping me to do in minutes, what took me many hours trying… Thanks a lot for that, much appreciated
      You’re welcome buddy. It wasn’t very long ago that I was in the very same place that you are in now. Some very fine people helped me get under way, and continue to help me. I repay them by helping others, where and when I can. I can see you’re in very good hands with Strawberry 3.141 assisting you. He was, and still is, instrumental in helping me perfect my MM. I’ll help you with the easy stuff. He’ll handle the genius side of things. :smile:
      • johnnyboyJ Offline
        johnnyboy @strawberry 3.141
        johnnyboyJ 1 Reply Last reply Reply Quote 0
          johnnyboy @johnnyboy
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @johnnyboy
            @johnnyboy only the part that i posted
                @johnnyboy if you have done npm install request moment than you can ignore the warnings about the missing file you’re good to continue, if you have done npm install --productive nothing happened because he cant read data out of an file that doesnt exist.
                    @johnnyboy in the config there is a modules: [] section put it right before the closing ]don’t forget to add a comma in front if there is none after the } from the last module in the section
                    johnnyboyJ 1 Reply Last reply Reply Quote 1
                        @johnnyboy in your magiccmirror directory you have the config directory and in their your config.js
                              strawberry 3.141S johnnyboyJ 2 Replies Last reply Reply Quote 0
                                @johnnyboy there is
                                  //all your configure modules
                                  //put the module at the end
                                        @johnnyboy you have to fill in your apikey
                                            @johnnyboy https://www.wunderground.com/weather/api/d/pricing
