    Adding Modules
    29 Posts 3 Posters 14.5k Views 3 Watching
    • johnnyboyJ Offline
      johnnyboy
      strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 2
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @johnnyboy
        @johnnyboy most of the modules are listed here https://github.com/MichMich/MagicMirror/wiki#3rd-party-modules
        Also most of the developers have install instructions in their readme file
        This module is what you are looking for https://github.com/RedNax67/MMM-WunderGround
        1. Open the terminal
        2. Go to the modules directory cd ~/MagicMirror/modules
        3. Clone the module git clone https://github.com/RedNax67/MMM-WunderGround.git
        (The following steps are not documented)
        4. Go to the module directory cd MMM-Wunderground
        5.As the developer did not provide a package.json file you have to manually install the dependencies, which are in this case request and moment, npm install request moment. If there is a package.json file you can just do npm install --productive which will install all dependencies defined by the developer or do npm install which will also download dependencies which are only needed for developing.
        (Back to the documented part)
        6. Add the module to the config
            module: 'MMM-WunderGround',
            position: 'top_right',
                apikey: 'xxxxxxxxxxxxx', // fill in your api_key that you applied for on wunderground
                pws: 'pws:IGELDERL219', //add your location for the weather service
                hourly: '1',
                fctext: '1',
                fcdaycount: "5",
                fcdaystart: "0",
                hourlyinterval: "3",
                hourlycount: "2",
                alerttime: 10000,
                alerttruncatestring: "english:",
            roundTmpDecs: 1,
            UseCardinals: 0,
            layout: "horizontal",
            sysstat: 0
        Don’t add the semicolon as it is in the readme this will cause issues. Then restart your mirror
        johnnyboyJ 2 Replies Last reply Reply Quote 3
          johnnyboy @strawberry 3.141
            Mykle1 Project Sponsor Module Developer @johnnyboy
            @johnnyboy said in Adding Modules:
            First off, a massive shout out to Mykle1 for helping me to do in minutes, what took me many hours trying… Thanks a lot for that, much appreciated
            You’re welcome buddy. It wasn’t very long ago that I was in the very same place that you are in now. Some very fine people helped me get under way, and continue to help me. I repay them by helping others, where and when I can. I can see you’re in very good hands with Strawberry 3.141 assisting you. He was, and still is, instrumental in helping me perfect my MM. I’ll help you with the easy stuff. He’ll handle the genius side of things. :smile:
              johnnyboyJ 1 Reply Last reply Reply Quote 0
                johnnyboy @johnnyboy
                  @johnnyboy only the part that i posted
                      @johnnyboy if you have done npm install request moment than you can ignore the warnings about the missing file you’re good to continue, if you have done npm install --productive nothing happened because he cant read data out of an file that doesnt exist.
