    Adding Modules
    29 Posts 3 Posters 14.7k Views 3 Watching
    • johnnyboyJ Offline
      johnnyboy @strawberry 3.141
        Mykle1 Project Sponsor Module Developer @johnnyboy
        @johnnyboy said in Adding Modules:
        First off, a massive shout out to Mykle1 for helping me to do in minutes, what took me many hours trying… Thanks a lot for that, much appreciated
        You’re welcome buddy. It wasn’t very long ago that I was in the very same place that you are in now. Some very fine people helped me get under way, and continue to help me. I repay them by helping others, where and when I can. I can see you’re in very good hands with Strawberry 3.141 assisting you. He was, and still is, instrumental in helping me perfect my MM. I’ll help you with the easy stuff. He’ll handle the genius side of things. :smile:
          johnnyboyJ 1 Reply Last reply Reply Quote 0
            johnnyboy @johnnyboy
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @johnnyboy
              @johnnyboy only the part that i posted
                  @johnnyboy if you have done npm install request moment than you can ignore the warnings about the missing file you’re good to continue, if you have done npm install --productive nothing happened because he cant read data out of an file that doesnt exist.
                      @johnnyboy in the config there is a modules: [] section put it right before the closing ]don’t forget to add a comma in front if there is none after the } from the last module in the section
                      johnnyboyJ 1 Reply Last reply Reply Quote 1
