    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 100.4k Views 16 Watching
      broberg Project Sponsor @Mykle1
      @Mykle1 Okey, I changed up some variables and I’m not able to test them myself, when you get home, could do a git pull on the doomsday module and test it out for me?
      Mykle1M 1 Reply Last reply
        broberg Project Sponsor @Jopyth
        @Jopyth Yes, I stripped out that module for this one, kept the start function and removed the rest since It was a bit over my head at the moment :)
        Took me a lot longer than I’m willing to admit just to get the code to compare dates!
        Actually thought about the hour/minute countdown as well, but decided to keep it real basic.
        I figured you don’t really put that many hours in front of the mirror that it would be that important to see so much detail of the countdown. (And if you look the update interval is set to 5 hours just to keep it in the ballpark)
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Jopyth
          @Jopyth said in MMM-doomsDay - The countdown module,:
          My advent module?
          Yes, that was it. :thumbsup_tone1:
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @broberg
            @broberg said in MMM-doomsDay - The countdown module,:
            when you get home, could do a git update on the doomsday module and test it out for me?
            This is what I get when I attempted a git update as you suggested.
            pi@Pi3:~/MagicMirror/modules/MMM-doomsDay $ git update
            git: ‘update’ is not a git command. See ‘git --help’.
            Did you mean this?
            update-ref
            I don’t want to mess anything up so I’ll wait till you advise further, thanks
            strawberry 3.141S B 2 Replies Last reply
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @Mykle1
              @Mykle1 git pull
                @Mykle1 sorry my bad mixing up stuff, git pull is the command to use in the Mmm-doomsday folder
                  A second to slow,@strawberry-3-141 beat me to it :)
                  • Mykle1M
                    A photo finish? Thanks to both of you. :thumbsup_tone1:
                        			module: 'MMM-doomsDay',
                        			position: 'top_left', // This can be any of the regions, best results in center regions
                            			doomsDay: "2017-02-24 24:00:00",  // the end day of the countdown, format is YYYY-MM-DD HH:MM:SS,
                            			toWhat: 'Open the pool!',  // the title of your countdown event
                    				present: 'We are gonna rock',  //  What it should say on doomsDay date
                    				singular: `Day Left`, // what it should say when it's only one day left, default is `Day Left`
                    				plural: 'Days Left', // what it should say when it's more days left, default is `Days Left`
                    Ok, now the display says, “Open the pool!”, but underneath is says, “0 Days Left”
                    B 1 Reply Last reply
                      @Mykle1 okey, then my fix didn’t do what I thought. I have restored it to as before, do a new git pull to get the last version again.
                      I will have to fix the half-day bug when I get back home :)
                      • Mykle1M
                        ok, will do. Sorry about the troubles
                          @Mykle1 no worries, first versions always have bugs :D
                          Mykle1M 2 Replies Last reply
                          • Mykle1M
                            I see you have a new designation.
                            Congratulations, Mr. Module Developer!
                            • Mykle1M
                              Just a follow up. I did the git pull to go back to the original version as you advised. I didn’t disable the module but I did set a new doomsDay for Tuesday. (This was yesterday) The module correctly reported “4 Days Left”. but as of this morning, it still reads "4 Days Left.
                                @Mykle1 Finally home, and I believe I have fixed this issue now!
                                do a new git pull and it should work in the mornings as well :D
                                @illskool You should also do an update on this module! :D
                                • Mykle1M
                                  Thanks bro. Gonna do that right now.
                                  Ok, I have my test running for tomorrow. The module is correctly displaying “1 Day Left”
                                      			position: 'top_right', // This can be any of the regions, best results in center regions
                                          			doomsDay: "2017-02-27 24:00:00", // the end day of the countdown
                                          			toWhat: 'Build Bed!', // the title of your countdown event
                                  				present: 'Get to it!',
                                  				singular: 'Day Left', // what it should say when it's only one day left, default is `Day Left`
                                  • Mykle1M
                                    @broberg
                                    It seems I’m still having some problems with this. It worked on the last test, and displayed the present: string correctly, but now it’s not working again. Below is my config with the doomsDay set for tomorrow and a screenshot of the display still reporting 2 Days Left
                                            			doomsDay: "2017-03-01 24:00:00", // the end day of the countdown
                                            			toWhat: 'Doctor Dave Wed', // the title of your countdown event
                                    				present: 'Doctor Dave 11:30',
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @Mykle1
                                      @Mykle1
                                      Somewhere between now and when I posted my previous comment, the module updated to 1 Day left.
                                        @Mykle1 I think a higher updateInterval may be in order. the 5 Hours set now maybe is a bit to much,
                                        in the config you can add
                                        updateInterval: 1 * 3600000,
                                        To set it to update every hour instead!
                                        • Mykle1M
                                          @broberg
                                          Done. I’ll keep you posted. Thanks for your time and effort. :thumbsup_tone1:
                                          B Mykle1M 2 Replies Last reply
                                            @Mykle1 And thank you for all the beta testing! :D
                                            Mykle1M 4 Replies Last reply
                                            • 1 / 4
