    Medicine Cabinet For Magic Mirror Frame
    15 Posts 7 Posters 11.7k Views 7 Watching
      bminer1
      Of course it could work. Just replace the mirror with a two way mirror and attach the monitor to the door. Run the wiring along the hinge side of the door and either have an outlet behind the cabinet or feed the power cable through the bottom or side to reach an outlet. Good luck and post some pictures!
        SoleLo
        @bminer1 I’ve seen tons of people building boxes and I’m thinking why wouldn’t they just use medicine cabinets since they are inexpensive and will probably be about the same depth when completed. Unless they just like being Bob The Builders, I can completely understand that I envy them. I’m going to head to Home Depot and Lowes in a bit and see what I can come up with.
        B Mykle1M 2 Replies Last reply
          bminer1 @SoleLo
          @SoleLo the reason why people build them could be because its cheaper to just buy a few pieces of wood and customize the size. med cabs are standardized and there is a door. some just build a frame, hang it and forget it. its all about the their preference.
          • Y
            yawns Moderator
            In fact there are several mirror projects using medicine cabinets and similar things.
            I won’t go this route for several reasons.
            1. If you go for the cabinet and still want to use it you have to live with the cabling and the technical components being visible while the cabinet is open.
            2. Cabinets are available in several sizes, but you have to adjust your mirror to the cabinet. If you build the mirror yourself you are free defining sizes.
            3. Users like me want to go for slim cases instead of “thick” cases standing away from the wall.
            4. As you already assumed several users like to build things. It’s not just having/using the mirror, it’s about building everything on your own.
            Of course it is absolutely legit buying a complete case/housing and start from there.
              SoleLo
              @bminer1 I completely get your point. It’s much easier to build around what you want than to build around the predefined size of the cabinet.
              @yawns , these are all great points. I I definitely want a slim case, I didn’t think about all that. As far as using the cabinet, I already have one, I’m just going to replace my other mirror with the cabinet, but now I’m having second thoughts. You just invoked some serious thinking and evaluating to get the right one.
              • Y
                yawns Moderator
                I’m sorry, I did not want to spoil your cabinet approach.
                Go for what makes you happy and what is possible for you :-)
                  SoleLo
                  @yawns you didn’t spoil it, you just made me think a little more and see things from a different light. I appreciate that. We are all here for stuff like that… Thanks!!!
                    B4rth
                    i think it can be a good idea, because iif you build the back slim and have a kind of cage/case around the back, it should be possible to still use the cabinet as a cabinet. would be very practical in smaller bathrooms.
                      SoleLo
                      @B4rth I’m going to look at the cabinets today to see if I can make a slim version or how the depth of them are in relation to what I’m trying to do.
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @SoleLo
                        @SoleLo said in Medicine Cabinet For Magic Mirror Frame:
                        It was a great feeling of satisfaction to make my own frame. It cost me $12 for the casing at Home Depot. Everything else I already had. :slight_smile:
                          SoleLo
                          @Mykle1 and I’m not gonna lie, your setup is sexy.
                          Mykle1M 1 Reply Last reply
                          • Mykle1M
                            Ahhh! haha, thanks. I took great pains to get it just the way I liked it. I’m still not done tweaking it. It’s way too much fun
                              SoleLo
                              @Mykle1 I’m starting to see all the fun, I’m mapping out all the modules I want and I still can’t decided. I don’t think I want more than 6 but damn there are soooooooo many amazing ones
                              • O
                                ottobot @SoleLo
                                @SoleLo If you’re going to recess the cabinet into the wall, you could make a cheap box out of 2x4’s a few inches bigger than the medicine cabinet to run all of your wiring into and keep it in the wall. Then just pop in some cleats to mount the medicine cabinet into. The displays that I try and use have USB ports on them that give out enough power to run a pi zero so the only cable/cord you would need would be power to the display itself. you could probably just use some cable staples to fasten the cord to the hinge side and keep it fairly clean looking.
