    How to put a module under another one
    5 Posts 4 Posters 3.8k Views 4 Watching
    • F Offline
      Fonfon
      HI,
      i try to put for exemple the module network scanner under the module forecast on the top left on the sreen ,
      but i can not .
      how is the region of screen ?
      and how configure it ?
      thanks ;)
      • cowboysdudeC Offline
        When you enter your info in the config.js just put in the order you want it in… for example
        			module: 'clock',
        			position: 'top_left'
                      {        module: 'network-scanner',
                                             options
        This will load the clock first then below it the network scanner… if you want them reversed then you put the network scanner first…
          Mykle1 Project Sponsor Module Developer @Fonfon
          @Fonfon said in How to put a module under another one:
          For a visual of the regions
          https://forum.magicmirror.builders/topic/286/regions
          johnnyboyJ 1 Reply Last reply Reply Quote 3
          • F Offline
            Fonfon
            lot of thanks !!
            • johnnyboyJ Offline
              johnnyboy @Mykle1
              @Mykle1
              Good to know, as i was not aware there was a yellow - upper_third or cyan - middle_centre zones available… just the magneta - lower_third for compliments.
              top_bar and bottom_bar are light gray
              top_left and bottom_left are red
              top_center and bottom_center are blue
              top_right and bottom_right are green
              upper_third is yellow
              middle_center is cyan
              lower_third is magenta
              All these regions will resize as needed.
