    New Raspberry Pi Zero W
    13 Posts 7 Posters 11.7k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @strawberry 3.141
      @strawberry-3.141 That’s hot!
      • cowboysdudeC Offline
        Thanks!! Got one on backorder :) Going to use it for this:
        http://www.hestiapi.com/home
          SoleLo
          Damn, I was just about to buy a regular 3 …I’ll wait…
          • jproehlJ Offline
            jproehl @strawberry 3.141
            @strawberry-3.141 Can the newly released RPI Zero W be used in place of an Rpi 3? I tried to swap my microSD card from an RPi 3 into a Pi Zero v1.3 and got an error on trying to start the Magic Mirror saying that the Pi Zero does use an acceptable version of some software.
            Has anyone ported the Magic Mirror source code so that it does work on an RPi Zero? If so, is that code available? If not, how difficult would it be to port it for the RPi Zero W??
              cowboysdude Module Developer @jproehl
              @jproehl There’s a forum here that another person got it to run on a Pi Zero I believe…
              https://forum.magicmirror.builders/topic/1711/pi-zero-mm
              https://forum.magicmirror.builders/topic/800/code-for-running-mm-on-pi-zero
              https://forum.magicmirror.builders/topic/98/pi-zero/11
              jproehlJ 1 Reply Last reply Reply Quote 0
              • jproehlJ Offline
                jproehl @cowboysdude
                @cowboysdude Great! Thanks, I’ll check it out. I’m trying to make a very compact mirror and the Pi Zero would assist the design, especially with the new wireless version of the Pi Zero just released.
                strawberry 3.141S 1 Reply Last reply Reply Quote 1
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @jproehl
                  @jproehl keep in mind that it has way less power than a rpi 3, some modules could “freeze” your mirror
                  jproehlJ 1 Reply Last reply Reply Quote 1
                  • jproehlJ Offline
                    @strawberry-3.141 Good point, thanks for the reminder. Maybe I’ll just stick with the RPi 3. The frame I’m making for my mirror will be two layers of 3/4" maple (I had some left over flooring material), since I’ve heard the RPi 3 can run a bit hotter than the other RPi models, would it be a good idea to leave off the top board on the back row (next to the wall) to allow for the heat to exit from behind the mirror?
                      McSorley
                      Bought one to swap out my raspberry pi 3 for another project. Starting from scratch, the curl script command doesnt work. What is the best way to get node.js installed from Pixel?
                        cowboysdude Module Developer @McSorley
                        @McSorley check here ->
                        http://raspberrypi.stackexchange.com/questions/48303/install-nodejs-for-all-raspberry-pi
                        and here
                        https://blog.miniarray.com/installing-node-js-on-a-raspberry-pi-zero-21a1522db2bb
