    Go East, young icon!
    22 Posts 5 Posters 16.6k Views 6 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Mykle1
      @Mykle1 you can achieve this without modifying the code
      custom.css
      .MMM-NetworkScanner .fa-ul li .fa-li {
        float: right;
      if this ends up with a to big gap you can limit the wifht of the list with
      .MMM-NetworkScanner .fa-ul {
        width: 200px;
      Mykle1M 2 Replies Last reply Reply Quote 3
        Mykle1 Project Sponsor Module Developer @strawberry 3.141
        @strawberry-3.141 said in Go East, young icon!:
        custom.css
        float: right;
        This did not work for me. The mobile icon remained on the left side of the device name. I should note that I already have an entry in custom.css for MMM-NetworkScanner. I tried your suggestion as a separate entry. Am I supposed to incorporate it into the existing entry?
        body {
        margin: 20px;
        height: calc(100% - 40px);
        width: calc(100% - 40px);
        margin-left: 2px;
        .MMM-WunderGround .max-temp {
        color: #f66;
          Mykle1 Project Sponsor Module Developer @tosti007
          @tosti007 said in Go East, young icon!:
          Note: I am currently on mobile so have no way of testing it. If it doesn’t work then let me know and i will search another solution (and I will be confused since I am pretty sure this works)
          I tried this after going the custom.css route and it did not work.
          Thank you for your suggestion
            Strawberry-3.141 deserves an award. He went above and beyond in helping me customize the NetworkScanner module for me. Apparently, he is a genius, and willing to work well past midnight to help someone (me) with their MM. You have my highest praise.
            All credit for this custom.css goes to Strawberry-3.141
            margin-left: 2px; /* This aligned NetworkScanner to the left margin /
            width: 130px; /
            If you remove this line it will be the same width as the widest module in the region, this can lead to a big gap, thats why i limited it to 130px if you add devices with longer names you might want to increase this value */
            .MMM-NetworkScanner .fa-li {
            position: relative; /* This put the icon on the right side */
            float: right;
            left: initial;
            I dreamed it. He made it happen.
            slametpsS 1 Reply Last reply Reply Quote 0
            • slametpsS Offline
              slametps @Mykle1
              @Mykle1 said in Go East, young icon!:
              width: 130px; / If you remove this line it will be the same width as the widest module in the region, this can lead to a big gap, thats why i limited it to 130px if you add devices with longer names you might want to increase this value /
              float: right;
              left: initial;
              @strawberry-3-141 : How to make icon on the left, but without margin?
              regards,
              Slamet PS
              Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
                Mykle1 Project Sponsor Module Developer @slametps
                @slametps said in Go East, young icon!:
                The icon is on the left by default
                  strawberry 3.141 Project Sponsor Module Developer @slametps
                  @slametps the space on the left ogf the icon or the space between the icon and the name?
                  • slametpsS Offline
                    slametps @strawberry 3.141
                    @strawberry-3.141 : the space on the left of the icon. How to remove it?
                    regards,
                    Slamet PS
                      Strawberry helped me with this. I’m not trying to answer for him, but while you’re waiting, this is what he did for me.
                      Add this to your custon.css file.
                        margin-left: 0px;
                      /* This aligned NetworkScanner to the left margin. Thanks to Strawberry-3.141 */
                      • slametpsS Offline
                        slametps @Mykle1
                          margin-left: 0px;
                        I’m using this on my custom.css, but still no luck.
                          margin-left: 1px;
                        the icon still has space I mention earlier.
                        regards,
                        Slamet PS
