    Go East, young icon!
    22 Posts 5 Posters 18.4k Views 6 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @tosti007
      @tosti007 said in Go East, young icon!:
      Note: I am currently on mobile so have no way of testing it. If it doesn’t work then let me know and i will search another solution (and I will be confused since I am pretty sure this works)
      I tried this after going the custom.css route and it did not work.
      Thank you for your suggestion
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @strawberry 3.141
        @strawberry-3.141 said in Go East, young icon!:
        you can achieve this without modifying the code
        Strawberry-3.141 deserves an award. He went above and beyond in helping me customize the NetworkScanner module for me. Apparently, he is a genius, and willing to work well past midnight to help someone (me) with their MM. You have my highest praise.
        All credit for this custom.css goes to Strawberry-3.141
        .MMM-NetworkScanner .fa-ul {
        margin-left: 2px; /* This aligned NetworkScanner to the left margin /
        width: 130px; /
        If you remove this line it will be the same width as the widest module in the region, this can lead to a big gap, thats why i limited it to 130px if you add devices with longer names you might want to increase this value */
        .MMM-NetworkScanner .fa-li {
        position: relative; /* This put the icon on the right side */
        float: right;
        left: initial;
        I dreamed it. He made it happen.
        slametpsS 1 Reply Last reply
        • slametpsS
          slametps @Mykle1
          @Mykle1 said in Go East, young icon!:
          width: 130px; / If you remove this line it will be the same width as the widest module in the region, this can lead to a big gap, thats why i limited it to 130px if you add devices with longer names you might want to increase this value /
          float: right;
          left: initial;
          @strawberry-3-141 : How to make icon on the left, but without margin?
          regards,
          Slamet PS
          Mykle1M strawberry 3.141S 2 Replies Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @slametps
            @slametps said in Go East, young icon!:
            The icon is on the left by default
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @slametps
              @slametps the space on the left ogf the icon or the space between the icon and the name?
              • slametpsS
                slametps @strawberry 3.141
                @strawberry-3.141 : the space on the left of the icon. How to remove it?
                regards,
                Slamet PS
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  Strawberry helped me with this. I’m not trying to answer for him, but while you’re waiting, this is what he did for me.
                  Add this to your custon.css file.
                    margin-left: 0px;
                  /* This aligned NetworkScanner to the left margin. Thanks to Strawberry-3.141 */
                  • slametpsS
                    slametps @Mykle1
                      margin-left: 0px;
                    I’m using this on my custom.css, but still no luck.
                      margin-left: 1px;
                    the icon still has space I mention earlier.
                    regards,
                    Slamet PS
                    • strawberry 3.141S
                      @slametps for me this works
                          margin-left: 35px;
                      • slametpsS
                            margin-left: 35px;
                        this style will cause the icon has a left-margin about 35px. what I want is the icon is left-aligned without a margin, and set margin-left to 0 or 1px is not working as expected.
                        regards,
                        Slamet PS
                        • strawberry 3.141S
                          @slametps can you share a screenshot? for me its aligned to the left
                          • slametpsS
                            using following css:
                              margin-left: 0px; /* This aligned NetworkScanner to the left margin */
                              width: 35 px; /* If you remove this line it will be the same width as the widest module in the region, this can lead to a big gap, thats why i limited it to 130px if you add devices with longer names you might want to increase this value */
                              float: left;
                              left: initial;
                              margin-left: 0px;
                            There are spaces between icon in NetworkScanner module and the left-edge. Is it possible to make it full left-aligned?
                            regards,
                            Slamet PS
                            • strawberry 3.141S
                              @slametps replace your rules with
                                  margin-left: 35px;
                                  left: -35px;
                                  text-align: initial;
                              • slametpsS
                                margin-left: 35px;
                                left: -35px;
                                Yap, this works. Thx a lot, @strawberry-3-141.
                                regards,
                                Slamet PS
                                • KimzerK
                                  Kimzer
                                  How do i change the color of the names?
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @Kimzer
                                    @Kimzer said in Go East, young icon!:
                                    In custom.css:
                                    .MMM-NetworkScanner {
                                      width: 175px;  /* should control width of entire module */
                                      color: #62FF00;  /* This may change the color of the icons, too */
                                    KimzerK 1 Reply Last reply
                                    • KimzerK
                                      Kimzer @Mykle1
                                      @Mykle1 Figured it out. But thanks ;)
