    Go East, young icon!
    22 Posts 5 Posters 18.4k Views 6 Watching
    • Mykle1M
      Hi all,
      I don’t even know if it’s possible, and it really isn’t necessary, but I’m trying to move the “mobile” icon in MMM-NetworkScanner from its place on the left of the device name to the right of the device name. I spent a good amount of time trying to achieve this, and I was trying where I probably shouldn’t ( the MMM-NetworkScanner.js file), and still no success.
      This is where the mobile icon appears by default, to the left of the devices name. 0_1487111032913_IMG_1741edit.jpg
      I’d rather it be here, on the right of the device name, where the smiley face is.0_1487111179700_IMG_1743edit2.jpg
      If this is the developers jurisdiction then I humbly acquiesce.
      Peace :peace:
      • T
        tosti007 Module Developer
        The reason why it’s a bad practice to change the maker’s code is because you cannot do an easy git pull anymore due to the changes. That means that every time there is a new version of the module you will have to redownload it and then modify the code again.
        That being said there is no way to get what you want without modifying the code, unless the maker adds this as a feature in the future.
        To get what you want you only have to change code inside MMM-NetworkScanner.js.
        Inside the getDom function you can find the lines:
        // Icon
        icon =  document.createElement("i");
        icon.classList.add("fa-li", "fa", "fa-" + device.icon);
        deviceItem.appendChild(icon);
        // Name
        deviceItem.innerHTML += device.name;
        All you have to do is change that part into:
        // Name
        // Icon
        So this is basically swapping the order in which the icon and the text are added to deviceItem.
        Hope this helps :D
        Note: I am currently on mobile so have no way of testing it. If it doesn’t work then let me know and i will search another solution (and I will be confused since I am pretty sure this works)
        If there is anything don’t hesitate to contact me!
        ProfileSwitcher, TouchNotifications
        Mykle1M 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @tosti007
          @tosti007 said in Go East, young icon!:
          It’s 7am here. I’m running off to work but I will try as soon as I get home. I will let you know. Many thanks.
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @Mykle1
            @Mykle1 you can achieve this without modifying the code
            custom.css
            .MMM-NetworkScanner .fa-ul li .fa-li {
              float: right;
            if this ends up with a to big gap you can limit the wifht of the list with
            .MMM-NetworkScanner .fa-ul {
              width: 200px;
            Reply Quote 3
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @strawberry 3.141
              @strawberry-3.141 said in Go East, young icon!:
              custom.css
              float: right;
              This did not work for me. The mobile icon remained on the left side of the device name. I should note that I already have an entry in custom.css for MMM-NetworkScanner. I tried your suggestion as a separate entry. Am I supposed to incorporate it into the existing entry?
              body {
              margin: 20px;
              height: calc(100% - 40px);
              width: calc(100% - 40px);
              margin-left: 2px;
              .MMM-WunderGround .max-temp {
              color: #f66;
              • Mykle1M
                I tried this after going the custom.css route and it did not work.
                Thank you for your suggestion
                • Mykle1M
                  Strawberry-3.141 deserves an award. He went above and beyond in helping me customize the NetworkScanner module for me. Apparently, he is a genius, and willing to work well past midnight to help someone (me) with their MM. You have my highest praise.
                  All credit for this custom.css goes to Strawberry-3.141
                  margin-left: 2px; /* This aligned NetworkScanner to the left margin /
                  width: 130px; /
                  If you remove this line it will be the same width as the widest module in the region, this can lead to a big gap, thats why i limited it to 130px if you add devices with longer names you might want to increase this value */
                  .MMM-NetworkScanner .fa-li {
                  position: relative; /* This put the icon on the right side */
                  float: right;
                  left: initial;
                  I dreamed it. He made it happen.
                  slametpsS 1 Reply Last reply
                  • slametpsS
                    slametps @Mykle1
                    @Mykle1 said in Go East, young icon!:
                    width: 130px; / If you remove this line it will be the same width as the widest module in the region, this can lead to a big gap, thats why i limited it to 130px if you add devices with longer names you might want to increase this value /
                    float: right;
                    left: initial;
                    @strawberry-3-141 : How to make icon on the left, but without margin?
                    regards,
                    Slamet PS
                    Mykle1M strawberry 3.141S 2 Replies Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @slametps
                      @slametps said in Go East, young icon!:
                      The icon is on the left by default
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @slametps
                        @slametps the space on the left ogf the icon or the space between the icon and the name?
                        • slametpsS
                          slametps @strawberry 3.141
                          @strawberry-3.141 : the space on the left of the icon. How to remove it?
                          regards,
                          Slamet PS
                          Mykle1M 1 Reply Last reply
                          • Mykle1M
                            Strawberry helped me with this. I’m not trying to answer for him, but while you’re waiting, this is what he did for me.
                            Add this to your custon.css file.
                              margin-left: 0px;
                            /* This aligned NetworkScanner to the left margin. Thanks to Strawberry-3.141 */
                            • slametpsS
                              slametps @Mykle1
                                margin-left: 0px;
                              I’m using this on my custom.css, but still no luck.
                                margin-left: 1px;
                              the icon still has space I mention earlier.
                              regards,
                              Slamet PS
                              • strawberry 3.141S
                                @slametps for me this works
                                    margin-left: 35px;
                                • slametpsS
                                      margin-left: 35px;
                                  this style will cause the icon has a left-margin about 35px. what I want is the icon is left-aligned without a margin, and set margin-left to 0 or 1px is not working as expected.
                                  regards,
                                  Slamet PS
                                  • strawberry 3.141S
                                    @slametps can you share a screenshot? for me its aligned to the left
                                    • slametpsS
                                      using following css:
                                        margin-left: 0px; /* This aligned NetworkScanner to the left margin */
                                        width: 35 px; /* If you remove this line it will be the same width as the widest module in the region, this can lead to a big gap, thats why i limited it to 130px if you add devices with longer names you might want to increase this value */
                                        float: left;
                                        left: initial;
                                        margin-left: 0px;
                                      There are spaces between icon in NetworkScanner module and the left-edge. Is it possible to make it full left-aligned?
                                      regards,
                                      Slamet PS
                                      • strawberry 3.141S
                                        @slametps replace your rules with
                                            margin-left: 35px;
                                            left: -35px;
                                            text-align: initial;
                                        • slametpsS
                                          margin-left: 35px;
                                          left: -35px;
                                          Yap, this works. Thx a lot, @strawberry-3-141.
                                          regards,
                                          Slamet PS
                                          • KimzerK
                                            Kimzer
                                            How do i change the color of the names?
