    MagicMirror does not work at startup
    19 Posts 6 Posters 19.2k Views 5 Watching
    • mpiresM Offline
      mpires
      You have Pm2 install?
      lucallmonL 2 Replies Last reply Reply Quote 0
      • lucallmonL Offline
        lucallmon @mpires
        @mpires Yes.
          lucallmon @mpires
          @mpires That got it working. I had to add in the directory. Thanks for all your help.
          • mpiresM Offline
            mpires
            no just put " pm2 start.sh "
            0_1488758016035_upload-7c9f1bfc-ddec-48c9-9879-941288a3005a
            • mpiresM Offline
              mpires
              Another happy person :D
                cassidycaid
                Thanks for the information. Using it I was able to figure out the steps for the command line.
                cd ~/.config/lxsession/LXDE-pi
                sudo nano autostart
                add to the end
                pm2 start mm.sh
                Thanks again for helping.
                mpiresM A 2 Replies Last reply Reply Quote 0
                • mpiresM Offline
                  mpires @cassidycaid
                  @cassidycaid yup is the same, i just show visual way, because is more simple for some ppl to understand.
                    amomat @cassidycaid
                    @cassidycaid Worked like a charm. Thanks a bunch.
                    • T Offline
                      TheSt33v
                      When I boot the pi, I see the MagicMirror boot screen, the desktop, and then MagicMirror boots. Following the steps above did not solve the problem. Is the desktop supposed to show up before MagicMirror boots, or is it supposed to go straight into MagicMirror? After I see the boot screen and right before I see the desktop, it briefly becomes a black screen with an X in the upper left corner of the screen. Any ideas on what might be wrong? I have pm2 installed and it is functioning perfectly.
                      • mpiresM Offline
                        mpires
                        Yes that is correct, you will always see the desktop for few seconds, then should open MM.
                        I think will happen the same with any other option you find to auto boot MM.
