    MagicMirror does not work at startup
    19 Posts 6 Posters 20.1k Views 5 Watching
    • lucallmonL
      lucallmon @mpires
      @mpires did you get it working with this script?
      • mpiresM
        mpires
        I have the script working, but the only way to start mm on boot, was set
        pm2 start mm
        on LXSession, but yes now once i boot my Pi, mm start without any problem.
        lucallmonL 2 Replies Last reply
        • lucallmonL
          lucallmon @mpires
          @mpires so in the LXSession configuration menu under ‘autostart’, simply add the line ‘pm2 start mm’ and it’ll run at boot?
          • lucallmonL
            lucallmon @mpires
            @mpires do I need an @ in front of it?
            • mpiresM
              mpires
              You have Pm2 install?
              • lucallmonL
                lucallmon @mpires
                @mpires Yes.
                • lucallmonL
                  lucallmon @mpires
                  @mpires That got it working. I had to add in the directory. Thanks for all your help.
                  • mpiresM
                    mpires
                    no just put " pm2 start.sh "
                    0_1488758016035_upload-7c9f1bfc-ddec-48c9-9879-941288a3005a
                    Reply Quote 2
                    • mpiresM
                      mpires
                      Another happy person :D
                        cassidycaid
                        Thanks for the information. Using it I was able to figure out the steps for the command line.
                        cd ~/.config/lxsession/LXDE-pi
                        sudo nano autostart
                        add to the end
                        pm2 start mm.sh
                        Thanks again for helping.
                        mpiresM A 2 Replies Last reply
                        • mpiresM
                          mpires @cassidycaid
                          @cassidycaid yup is the same, i just show visual way, because is more simple for some ppl to understand.
                          • A
                            amomat @cassidycaid
                            @cassidycaid Worked like a charm. Thanks a bunch.
                            • T
                              TheSt33v
                              When I boot the pi, I see the MagicMirror boot screen, the desktop, and then MagicMirror boots. Following the steps above did not solve the problem. Is the desktop supposed to show up before MagicMirror boots, or is it supposed to go straight into MagicMirror? After I see the boot screen and right before I see the desktop, it briefly becomes a black screen with an X in the upper left corner of the screen. Any ideas on what might be wrong? I have pm2 installed and it is functioning perfectly.
                              • mpiresM
                                mpires
                                Yes that is correct, you will always see the desktop for few seconds, then should open MM.
                                I think will happen the same with any other option you find to auto boot MM.
