    MagicMirror does not work at startup
    19 Posts 6 Posters 19.2k Views 5 Watching
      martirius
      Hi guys,
      i followed the guide on GitHub to make it starts at startup but it does not work…
      When RaspBerry startup, appear on the screen The MagicMirror logo and it says booting up, but after that the screen disappear and the normal Debian jessie Desktop appears… how to make it work?
        cassidycaid
        I also am having issues with auto start of the script.
        New install on raspberry pi 3 B.
        The manual start, stop and restart commands all work and when I run the pm2 save command, it does not error.
        After a reboot the mm.sh does not autostart.
          amomat
          Also having this issue. pm2 start mm.sh works. MM2 boot up screen appears on start up. But loads to desktop.
          • lucallmonL Offline
            lucallmon
            I am having this problem too. This is the 4th time I’ve installed MM on a RPI 3 and I don’t know what’s changed recently, but it’s not loading at boot. I followed the AutoStart wiki to the T but it won’t autostart.
            @MichMich @KirAsh4 @cowboysdude @ianperrin @yawns @Jopyth @morozgrafix - can any of you guys weigh in on this? This is kind of a big issue that it seems many folks are having.
            • mpiresM Offline
              mpires
              I have the same issue, i did put java scrip on startup, i did look on the forum and #sebzx10r, suggest the same solution.
              https://forum.magicmirror.builders/topic/1094/pm2-mm2-not-starting-on-start-up/15
              In Raspian click Menu,Preferences,Main Menu Editor
              Click Preferences and check Default applications for LXSession
              Click OK and close main menu editor
              Now click Menu and Under Preferences click on Default applications for LXSession
              LXSession configuration opens
              Click Autostart
              Under Manual autostarted applications paste in your java command line
              click add
              close the LXSession configuration application and reboot your pi
              your java app should run after reboot
              Hope this help.
              Cheers,
              lucallmonL 1 Reply Last reply Reply Quote 0
                lucallmon @mpires
                @mpires did you get it working with this script?
                • mpiresM Offline
                  mpires
                  I have the script working, but the only way to start mm on boot, was set
                  pm2 start mm
                  on LXSession, but yes now once i boot my Pi, mm start without any problem.
                  lucallmonL 2 Replies Last reply Reply Quote 0
                    lucallmon @mpires
                    @mpires so in the LXSession configuration menu under ‘autostart’, simply add the line ‘pm2 start mm’ and it’ll run at boot?
                      lucallmon @mpires
                      @mpires do I need an @ in front of it?
                      • mpiresM Offline
                        mpires
                        You have Pm2 install?
                          lucallmon @mpires
                          @mpires Yes.
                            lucallmon @mpires
                            @mpires That got it working. I had to add in the directory. Thanks for all your help.
                            • mpiresM Offline
                              mpires
                              no just put " pm2 start.sh "
                              0_1488758016035_upload-7c9f1bfc-ddec-48c9-9879-941288a3005a
                              • mpiresM Offline
                                mpires
                                Another happy person :D
                                  cassidycaid
                                  Thanks for the information. Using it I was able to figure out the steps for the command line.
                                  cd ~/.config/lxsession/LXDE-pi
                                  sudo nano autostart
                                  add to the end
                                  pm2 start mm.sh
                                  Thanks again for helping.
                                  mpiresM A 2 Replies Last reply Reply Quote 0
                                  • mpiresM Offline
                                    mpires @cassidycaid
                                    @cassidycaid yup is the same, i just show visual way, because is more simple for some ppl to understand.
                                      amomat @cassidycaid
                                      @cassidycaid Worked like a charm. Thanks a bunch.
                                      • T Offline
                                        TheSt33v
                                        When I boot the pi, I see the MagicMirror boot screen, the desktop, and then MagicMirror boots. Following the steps above did not solve the problem. Is the desktop supposed to show up before MagicMirror boots, or is it supposed to go straight into MagicMirror? After I see the boot screen and right before I see the desktop, it briefly becomes a black screen with an X in the upper left corner of the screen. Any ideas on what might be wrong? I have pm2 installed and it is functioning perfectly.
                                        • mpiresM Offline
                                          mpires
                                          Yes that is correct, you will always see the desktop for few seconds, then should open MM.
                                          I think will happen the same with any other option you find to auto boot MM.
