    MagicMirror does not work at startup
    19 Posts 6 Posters 18.7k Views 5 Watching
    • lucallmonL Offline
      lucallmon @mpires
      @mpires did you get it working with this script?
      • mpiresM Offline
        mpires
        I have the script working, but the only way to start mm on boot, was set
        pm2 start mm
        on LXSession, but yes now once i boot my Pi, mm start without any problem.
        lucallmonL 2 Replies Last reply Reply Quote 0
          lucallmon @mpires
          @mpires so in the LXSession configuration menu under ‘autostart’, simply add the line ‘pm2 start mm’ and it’ll run at boot?
            lucallmon @mpires
            @mpires do I need an @ in front of it?
            • mpiresM Offline
              mpires
              You have Pm2 install?
                lucallmon @mpires
                @mpires Yes.
                  lucallmon @mpires
                  @mpires That got it working. I had to add in the directory. Thanks for all your help.
                  • mpiresM Offline
                    mpires
                    no just put " pm2 start.sh "
                    0_1488758016035_upload-7c9f1bfc-ddec-48c9-9879-941288a3005a
                    • mpiresM Offline
                      mpires
                      Another happy person :D
                        cassidycaid
                        Thanks for the information. Using it I was able to figure out the steps for the command line.
                        cd ~/.config/lxsession/LXDE-pi
                        sudo nano autostart
                        add to the end
                        pm2 start mm.sh
                        Thanks again for helping.
                        mpiresM A 2 Replies Last reply Reply Quote 0
