    MagicMirror does not work at startup
    19 Posts 6 Posters 19.9k Views 5 Watching
    • A
      amomat
      Also having this issue. pm2 start mm.sh works. MM2 boot up screen appears on start up. But loads to desktop.
      • L
        lucallmon
        I am having this problem too. This is the 4th time I’ve installed MM on a RPI 3 and I don’t know what’s changed recently, but it’s not loading at boot. I followed the AutoStart wiki to the T but it won’t autostart.
        @MichMich @KirAsh4 @cowboysdude @ianperrin @yawns @Jopyth @morozgrafix - can any of you guys weigh in on this? This is kind of a big issue that it seems many folks are having.
        • mpiresM
          mpires
          I have the same issue, i did put java scrip on startup, i did look on the forum and #sebzx10r, suggest the same solution.
          https://forum.magicmirror.builders/topic/1094/pm2-mm2-not-starting-on-start-up/15
          In Raspian click Menu,Preferences,Main Menu Editor
          Click Preferences and check Default applications for LXSession
          Click OK and close main menu editor
          Now click Menu and Under Preferences click on Default applications for LXSession
          LXSession configuration opens
          Click Autostart
          Under Manual autostarted applications paste in your java command line
          click add
          close the LXSession configuration application and reboot your pi
          your java app should run after reboot
          Hope this help.
          Cheers,
          • L
            lucallmon @mpires
            @mpires did you get it working with this script?
            • mpiresM
              mpires
              I have the script working, but the only way to start mm on boot, was set
              pm2 start mm
              on LXSession, but yes now once i boot my Pi, mm start without any problem.
              L 2 Replies Last reply Reply Quote 0
              • L
                lucallmon @mpires
                @mpires so in the LXSession configuration menu under ‘autostart’, simply add the line ‘pm2 start mm’ and it’ll run at boot?
                • L
                  lucallmon @mpires
                  @mpires do I need an @ in front of it?
                  • mpiresM
                    mpires
                    You have Pm2 install?
                    • L
                      lucallmon @mpires
                      @mpires Yes.
                      • L
                        lucallmon @mpires
                        @mpires That got it working. I had to add in the directory. Thanks for all your help.
                        • mpiresM
                          mpires
                          no just put " pm2 start.sh "
                          0_1488758016035_upload-7c9f1bfc-ddec-48c9-9879-941288a3005a
                          • mpiresM
                            mpires
                            Another happy person :D
                              cassidycaid
                              Thanks for the information. Using it I was able to figure out the steps for the command line.
                              cd ~/.config/lxsession/LXDE-pi
                              sudo nano autostart
                              add to the end
                              pm2 start mm.sh
                              Thanks again for helping.
                              mpiresM A 2 Replies Last reply Reply Quote 0
                              • mpiresM
                                mpires @cassidycaid
                                @cassidycaid yup is the same, i just show visual way, because is more simple for some ppl to understand.
                                • A
                                  amomat @cassidycaid
                                  @cassidycaid Worked like a charm. Thanks a bunch.
                                  • T
                                    TheSt33v
                                    When I boot the pi, I see the MagicMirror boot screen, the desktop, and then MagicMirror boots. Following the steps above did not solve the problem. Is the desktop supposed to show up before MagicMirror boots, or is it supposed to go straight into MagicMirror? After I see the boot screen and right before I see the desktop, it briefly becomes a black screen with an X in the upper left corner of the screen. Any ideas on what might be wrong? I have pm2 installed and it is functioning perfectly.
                                    • mpiresM
                                      mpires
                                      Yes that is correct, you will always see the desktop for few seconds, then should open MM.
                                      I think will happen the same with any other option you find to auto boot MM.
