Using an Old (2 years old) windows Laptop in place of raspberry pi.
6 Posts 4 Posters 5.3k Views 4 Watching
    jakef0523
    I’ve only just discovered magic mirror and i would like to build one, I have an old laptop that I don’t use anymore, i switched to OSX, and was wondering if/how I could use the laptop instead of buying a new system, I have all the parts to build one already, I’m just unable to find a guide where I could find a way to use the pc instead.
      mortenbirkelund
      Install linux on the laptop, and then install magicmirror using the manuall installation as found here.
      https://github.com/MichMich/MagicMirror
      Perhaps there will be some glitches because MagicMirror was designed for raspberry pi but I did it with an old laptop for testing purpose and it worked fine. Currently I am working with magicmirror on a windows machine, and here i get a lot more glitches because i cant install the same programs (“sudo apt-get” doesnt exist ;)
      J 1 Reply Last reply Mar 8, 2017, 10:27 AM Reply Quote 0
        johnnyboy @mortenbirkelund
        M M 2 Replies Last reply Mar 8, 2017, 10:31 AM Reply Quote 0
          mortenbirkelund @johnnyboy
          @johnnyboy missing something.
          I’ve tried it on a Linux laptop and a Windows laptop.
          On Linux it worked good, but on the windows machine partially worked, as I am limited by the fact that some of the programs that are needed can’t be installed as they only works on Linux.
          J 1 Reply Last reply Mar 8, 2017, 11:49 AM Reply Quote 1
            Mykle1 Project Sponsor Module Developer @johnnyboy
            @johnnyboy said in Using an Old (2 years old) windows Laptop in place of raspberry pi.:
            Im confused…
            I know. :stuck_out_tongue_winking_eye:
            I, too, started with a Windows machine, but it is possible to install MM and get it running, just in a roundabout way.
            Then I installed uBuntu on a laptop and installed MM and that went quite smoothly.
            You want the best of both worlds? When you install uBuntu on a PC or laptop there is an option to install it alongside of Windows, making it a dual boot machine.
