Modules
9 Posts 4 Posters 4.6k Views 5 Watching
  • G Offline
    gmigliarini
    I do not have much experience but I have it working, but when I want to put ADULT MODULES I get this error. Copy all in config / config.js
    And I charge the program in MODULES. Can you help me. Thank you so much.0_1489629881375_IMG_1088.JPG
    M 1 Reply Last reply Mar 16, 2017, 2:27 AM Reply Quote 1
      Mykle1 Project Sponsor Module Developer @gmigliarini
      @gmigliarini said in Modules:
      Post your config here so people can see what the problem is. Someone will help you
      • G Offline
        gmigliarini
        Using the module
                module: 'email',
                    position: 'bottom_left',
                    header: 'Email',
                    config:{
                        user: 'johndoe@gmail.com',
                        password: 'xxx',
                        host: 'imap.gmail.com',
                        port: 993,
                        tls: true,
                        authTimeout: 10000,
                        numberOfEmails: 5,
                        fade: true
        M 1 Reply Last reply Mar 16, 2017, 3:39 AM Reply Quote 0
          @gmigliarini
          ok, to add this to your config here is an example on adding it between other modules already in your config.js file
          			module: 'helloworld',
          			position: 'top_bar',
          			classes: 'small bright',
          			text: 'Magic Mirror!'
          		},   // Mine ends here at the },
                          {   //Yours starts here at the {
                                  module: ‘email’,
                                  position: ‘bottom_left’,
                                  header: ‘Email’,
                                  config:{
                                  user: ‘johndoe@gmail.com’,
                                  password: ‘xxx’,
                                  host: ‘imap.gmail.com’,
                                  port: 993,
                                  tls: true,
                                  authTimeout: 10000,
                                  numberOfEmails: 5,
                                  fade: true
                          }   // No comma here!
                          },  // Yours ends here at the },
                          {   // Another one of mine begins
          			module: 'updatenotification',
          			updateInterval: 600000 // (10 minutes);
          Notice how there are no [ or ] in what you are adding. And also notice that I changed the last 2 } of yours. I removed the comma from the 2nd to last } and added a comma to the last }. Do the same when you add your entry. Look at mine to see how to add it correctly.
          • G Offline
            gmigliarini
            Many thanks for the help try everything and it does not work, my mirror works normally but when putting a MODULE does not work anymore. My email is gmigliarini@cox.net and I have TEAMVIEWER placed and you can enter. Thank you so much.
            Y 1 Reply Last reply Mar 16, 2017, 3:21 PM Reply Quote 0
            • Y Offline
              yawns Moderator @gmigliarini
              @gmigliarini
              Just to be sure … did you git clone the email module into the right module folder?
              cd ~/MagicMirror/modules
              git clone https://github.com/ronny3050/email-mirror.git email
              cd email
              npm install
              L 1 Reply Last reply May 21, 2017, 8:31 AM Reply Quote 0
              • G Offline
                gmigliarini
                Yes, my mirror works but adding MODULES does not work anymore and I have everything like that, I have TeamViewer on the raspberry 3 if you want to login. My email is gmigliarini@cox.net.
                • Y Offline
                  yawns Moderator
                  Please send me your teamviewer id and the password, I contacted you via chat
                  • L Offline
                    lsaguiar @yawns
                    @yawns I had install as your explanation, everything works, but no new emails are displaying, always have “no new email” and I have some there. How can I solve the issue? Many thanks in advance.
