    Modules
    9 Posts 4 Posters 5.8k Views 5 Watching
    • G
      gmigliarini
      I do not have much experience but I have it working, but when I want to put ADULT MODULES I get this error. Copy all in config / config.js
      And I charge the program in MODULES. Can you help me. Thank you so much.0_1489629881375_IMG_1088.JPG
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @gmigliarini
        @gmigliarini said in Modules:
        Post your config here so people can see what the problem is. Someone will help you
        • G
          gmigliarini
          Using the module
                  module: 'email',
                      position: 'bottom_left',
                      header: 'Email',
                      config:{
                          user: 'johndoe@gmail.com',
                          password: 'xxx',
                          host: 'imap.gmail.com',
                          port: 993,
                          tls: true,
                          authTimeout: 10000,
                          numberOfEmails: 5,
                          fade: true
          • Mykle1M
            @gmigliarini
            ok, to add this to your config here is an example on adding it between other modules already in your config.js file
            			module: 'helloworld',
            			position: 'top_bar',
            			classes: 'small bright',
            			text: 'Magic Mirror!'
            		},   // Mine ends here at the },
                            {   //Yours starts here at the {
                                    module: ‘email’,
                                    position: ‘bottom_left’,
                                    header: ‘Email’,
                                    config:{
                                    user: ‘johndoe@gmail.com’,
                                    password: ‘xxx’,
                                    host: ‘imap.gmail.com’,
                                    port: 993,
                                    tls: true,
                                    authTimeout: 10000,
                                    numberOfEmails: 5,
                                    fade: true
                            }   // No comma here!
                            },  // Yours ends here at the },
                            {   // Another one of mine begins
            			module: 'updatenotification',
            			updateInterval: 600000 // (10 minutes);
            Notice how there are no [ or ] in what you are adding. And also notice that I changed the last 2 } of yours. I removed the comma from the 2nd to last } and added a comma to the last }. Do the same when you add your entry. Look at mine to see how to add it correctly.
            • G
              gmigliarini
              Many thanks for the help try everything and it does not work, my mirror works normally but when putting a MODULE does not work anymore. My email is gmigliarini@cox.net and I have TEAMVIEWER placed and you can enter. Thank you so much.
              Y 1 Reply Last reply
              • Y
                yawns Moderator @gmigliarini
                @gmigliarini
                Just to be sure … did you git clone the email module into the right module folder?
                cd ~/MagicMirror/modules
                git clone https://github.com/ronny3050/email-mirror.git email
                cd email
                npm install
                L 1 Reply Last reply
                • G
                  gmigliarini
                  Yes, my mirror works but adding MODULES does not work anymore and I have everything like that, I have TeamViewer on the raspberry 3 if you want to login. My email is gmigliarini@cox.net.
                  • Y
                    yawns Moderator
                    Please send me your teamviewer id and the password, I contacted you via chat
                    • L
                      lsaguiar @yawns
                      @yawns I had install as your explanation, everything works, but no new emails are displaying, always have “no new email” and I have some there. How can I solve the issue? Many thanks in advance.
