    Default Weather module not loading and no error showing.
    31 Posts 9 Posters 42.3k Views 8 Watching
      Preve
      Hi all,
      I’m new at this magic mirror thingie. Just installed it on a raspberry Pi 2 and got my screen. Everything loads well (Private calendar, Compliments and personalized new feed.) What doesn’t work is the Weather module. It’s not showing at all. So I don’t get any kind of error.
      I’ve entered my API key and location found in the openweatherpmap website. But space where the module should be on my screen is empty. No error, not a word.
      Anyone that can help me? Maybe I forgot to enable something?
      Kind regards
      • yawnsY Offline
        yawns Moderator @Preve
        @Preve
        Please post your config, but replace your personal keys/calendar links with XXX
          Preve
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: 'en',
          	timeFormat: 24,
          	units: 'metric',
          			module: 'alert',
          			module: "updatenotification",
          			position: "top_bar"
          			module: 'clock',
          			position: 'top_left'
          			module: 'calendar',
          			header: 'Personal Calendar',
          			position: 'top_left',
                                                          symbol: 'calendar-check-o ',
                                                          url: 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
          			module: 'compliments',
          			position: 'lower_third'
          			module: 'currentweather',
          			position: 'top_right',
          				locationID: '2802154',
          				appid: 'XXXXXXXXXXXXXXXXXXXXXXX'
          			module: 'weatherforecast',
          			header: 'Weather Forecast',
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "HLN BE",
          						url: "http://www.hln.be/rss.xml"
          				showSourceTitle: true,
          				showPublishDate: true
          • yawnsY Offline
            yawns Moderator
            That in fact looks perfectly fine. Did you try to reboot your pi to check if currentweather comes up?
            Try to press F12 in the browser while MagicMirror is running and check the console for errors
              Preve
              Restarted MM a couple of times. I’ll reboot the PI and see what’s happening.
                Preve @Preve
                Nope, Rebooted the PI and still nothing.
                • yawnsY Offline
                  yawns Moderator
                  And console of your browser does not show a single error?
                    Preve
                    How do I get there? Sorry for noobish question. It runs full screen.
                    • yawnsY Offline
                      yawns Moderator
                      If you press F12 in your browser you should see a development interface, one is called console and should show information, warnings and - maybe - errors
                      • yawnsY Offline
                        yawns Moderator
                        I just tried your currentweather settings with my appid and instantly see the current weather. Did you check your appid again?
                        • 1 / 4
