    Default Weather module not loading and no error showing.
    31 Posts 9 Posters 44.8k Views 8 Watching
    • Y
      yawns Moderator
      And console of your browser does not show a single error?
        Preve
        How do I get there? Sorry for noobish question. It runs full screen.
        • Y
          yawns Moderator
          If you press F12 in your browser you should see a development interface, one is called console and should show information, warnings and - maybe - errors
          • Y
            yawns Moderator
            I just tried your currentweather settings with my appid and instantly see the current weather. Did you check your appid again?
              Preve
              Registerd to the site, asked an API and that API shows in “my api” folder on the website. Already removed it and re-entered it.
                Preve
                Isn’t there a log file I can check?
                • Y
                  yawns Moderator
                  would you send me your api key by private message/chat?
                  • Y
                    yawns Moderator @Preve
                    @Preve said in Default Weather module not loading and no error showing.:
                    Yes, there is.
                    If you are starting your magicmirror with pm2 you can run pm2 logs mm to check for errors. And you can check the browser console
                      Preve
                      0|mm | No helper found for module: currentweather.
                      0|mm | No helper found for module: weatherforecast.
                      0|mm | Initializing new module helper …
                      0|mm | All module helpers loaded.
                      0|mm | Starting server op port 8080 …
                      0|mm | Server started …
                      0|mm | Connecting socket for: updatenotification
                      0|mm | Connecting socket for: calendar
                      0|mm | Starting node helper for: calendar
                      0|mm | Connecting socket for: newsfeed
                      0|mm | Starting module: newsfeed
                      0|mm | Sockets connected & modules started …
                      0|mm | Launching application.
                      0|mm | Create new calendar fetcher for url: XXXXXXXXXXXXXXXXXXXXXXXX - Interval: 300000
                      0|mm | Create new news fetcher for url: http://www.hln.be/rss.xml - Interval: 300000
                      That’s in the mm-out-0.log.
                      The mm-error-0.log is empty
                        Preve
                        The strange thing… I install another weather module MMM_Wunderground, get an API key and it works. Just copy pasted in the config.js and changed the API and pws. restarted MM and got directly what I needed. Strange. very strange.
                          broberg Project Sponsor
                          I’ve had it malfunction a couple of time to, but it usually starts working again after a couple of hours/next day. Seems to me that i’s a connection issue since I don’t change anything for it to work again.
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Preve
                            @Preve when I applied for the API Key it wasn’t working for a while as well. I had to wait until it was ready to use in their system.
                              Preve @broberg
                              @broberg But when the API-key is wrong or maybe too soon used, wouldn’t you get any kind of loading error? In my case there was nothing showing on my screen.
                              • Y
                                Yes, it does show this alert. As I said … Press F12, change to console and look for errors. I removed one character in my appid, and this is what happens:
                                  Preve @yawns
                                  @yawns Finally found a way to get in the browser. I’m quite happy with the new weather module. So I stop this thread and mark it as solved in some kind of.
                                  Thank you all for all efforts.
                                  Now the search begins to have a good MP3/radio station player. I would like to build in some speakers I have in my garage and give them a new function in this project.
                                    Pran
                                    I am having the same problem right now. I was previously using the default weather module and it was working perfectly fine. However, due to some reasons, I had to uninstall everything on my Pi and start working with a fresh install of OS to everything else.
                                    I installed MM2 again, made necessary changes in config but somehow the weather module is not showing up.
                                    I even tried looking at logs but there is no error there. Even in the browser console.
                                    It would be really appreciated if someone could help me with this.
                                    • G
                                      gznoble @Preve
                                      @Preve Could you post the solution you found?
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @gznoble
                                        @gznoble said in Default Weather module not loading and no error showing.:
                                        Your default weather is not working? Post your config entry for weather here using this guide. We’ll try to get you sorted.
                                          BlackTalon
                                          My config for weatherforecast is not working. The odd thing is that current weather is. I can not see the console with F12. I thought this was a keyboard config issue but I have tried several settings and F12 is not bringing up the console.
                                            BlackTalon @BlackTalon
