Default Weather module not loading and no error showing.
31 Posts 9 Posters 41.0k Views 8 Watching
    Preve
    Hi all,
    I’m new at this magic mirror thingie. Just installed it on a raspberry Pi 2 and got my screen. Everything loads well (Private calendar, Compliments and personalized new feed.) What doesn’t work is the Weather module. It’s not showing at all. So I don’t get any kind of error.
    I’ve entered my API key and location found in the openweatherpmap website. But space where the module should be on my screen is empty. No error, not a word.
    Anyone that can help me? Maybe I forgot to enable something?
    Kind regards
    Y 1 Reply Last reply Mar 16, 2017, 4:13 PM Reply Quote 0
    • Y Offline
      yawns Moderator @Preve
      @Preve
      Please post your config, but replace your personal keys/calendar links with XXX
        Preve
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: 'en',
        	timeFormat: 24,
        	units: 'metric',
        			module: 'alert',
        			module: "updatenotification",
        			position: "top_bar"
        			module: 'clock',
        			position: 'top_left'
        			module: 'calendar',
        			header: 'Personal Calendar',
        			position: 'top_left',
                                                        symbol: 'calendar-check-o ',
                                                        url: 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
        			module: 'compliments',
        			position: 'lower_third'
        			module: 'currentweather',
        			position: 'top_right',
        				locationID: '2802154',
        				appid: 'XXXXXXXXXXXXXXXXXXXXXXX'
        			module: 'weatherforecast',
        			header: 'Weather Forecast',
        			module: 'newsfeed',
        			position: 'bottom_bar',
        				feeds: [
        						title: "HLN BE",
        						url: "http://www.hln.be/rss.xml"
        				showSourceTitle: true,
        				showPublishDate: true
        • Y Offline
          yawns Moderator
          That in fact looks perfectly fine. Did you try to reboot your pi to check if currentweather comes up?
          Try to press F12 in the browser while MagicMirror is running and check the console for errors
            Preve
            Restarted MM a couple of times. I’ll reboot the PI and see what’s happening.
            P 1 Reply Last reply Mar 16, 2017, 4:25 PM Reply Quote 0
              Preve @Preve
              Nope, Rebooted the PI and still nothing.
              • Y Offline
                yawns Moderator
                And console of your browser does not show a single error?
                  Preve
                  How do I get there? Sorry for noobish question. It runs full screen.
                  • Y Offline
                    yawns Moderator
                    If you press F12 in your browser you should see a development interface, one is called console and should show information, warnings and - maybe - errors
                    • Y Offline
                      yawns Moderator
                      I just tried your currentweather settings with my appid and instantly see the current weather. Did you check your appid again?
                      • 1 / 4
                      1 / 4
