    Default Weather module not loading and no error showing.
    31 Posts 9 Posters 45.1k Views 8 Watching
      Preve
      Hi all,
      I’m new at this magic mirror thingie. Just installed it on a raspberry Pi 2 and got my screen. Everything loads well (Private calendar, Compliments and personalized new feed.) What doesn’t work is the Weather module. It’s not showing at all. So I don’t get any kind of error.
      I’ve entered my API key and location found in the openweatherpmap website. But space where the module should be on my screen is empty. No error, not a word.
      Anyone that can help me? Maybe I forgot to enable something?
      Kind regards
      yawnsY 1 Reply Last reply
      • yawnsY
        yawns Moderator @Preve
        @Preve
        Please post your config, but replace your personal keys/calendar links with XXX
          Preve
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: 'en',
          	timeFormat: 24,
          	units: 'metric',
          			module: 'alert',
          			module: "updatenotification",
          			position: "top_bar"
          			module: 'clock',
          			position: 'top_left'
          			module: 'calendar',
          			header: 'Personal Calendar',
          			position: 'top_left',
                                                          symbol: 'calendar-check-o ',
                                                          url: 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
          			module: 'compliments',
          			position: 'lower_third'
          			module: 'currentweather',
          			position: 'top_right',
          				locationID: '2802154',
          				appid: 'XXXXXXXXXXXXXXXXXXXXXXX'
          			module: 'weatherforecast',
          			header: 'Weather Forecast',
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "HLN BE",
          						url: "http://www.hln.be/rss.xml"
          				showSourceTitle: true,
          				showPublishDate: true
          • yawnsY
            yawns Moderator
            That in fact looks perfectly fine. Did you try to reboot your pi to check if currentweather comes up?
            Try to press F12 in the browser while MagicMirror is running and check the console for errors
              Preve
              Restarted MM a couple of times. I’ll reboot the PI and see what’s happening.
              P 1 Reply Last reply
                Preve @Preve
                Nope, Rebooted the PI and still nothing.
                • yawnsY
                  yawns Moderator
                  And console of your browser does not show a single error?
                    Preve
                    How do I get there? Sorry for noobish question. It runs full screen.
                    • yawnsY
                      yawns Moderator
                      If you press F12 in your browser you should see a development interface, one is called console and should show information, warnings and - maybe - errors
                      • yawnsY
                        yawns Moderator
                        I just tried your currentweather settings with my appid and instantly see the current weather. Did you check your appid again?
                          Preve
                          Registerd to the site, asked an API and that API shows in “my api” folder on the website. Already removed it and re-entered it.
                            Preve
                            Isn’t there a log file I can check?
                            • yawnsY
                              yawns Moderator
                              would you send me your api key by private message/chat?
                              • yawnsY
                                @Preve said in Default Weather module not loading and no error showing.:
                                Yes, there is.
                                If you are starting your magicmirror with pm2 you can run pm2 logs mm to check for errors. And you can check the browser console
                                  Preve
                                  0|mm | No helper found for module: currentweather.
                                  0|mm | No helper found for module: weatherforecast.
                                  0|mm | Initializing new module helper …
                                  0|mm | All module helpers loaded.
                                  0|mm | Starting server op port 8080 …
                                  0|mm | Server started …
                                  0|mm | Connecting socket for: updatenotification
                                  0|mm | Connecting socket for: calendar
                                  0|mm | Starting node helper for: calendar
                                  0|mm | Connecting socket for: newsfeed
                                  0|mm | Starting module: newsfeed
                                  0|mm | Sockets connected & modules started …
                                  0|mm | Launching application.
                                  0|mm | Create new calendar fetcher for url: XXXXXXXXXXXXXXXXXXXXXXXX - Interval: 300000
                                  0|mm | Create new news fetcher for url: http://www.hln.be/rss.xml - Interval: 300000
                                  That’s in the mm-out-0.log.
                                  The mm-error-0.log is empty
                                    Preve
                                    The strange thing… I install another weather module MMM_Wunderground, get an API key and it works. Just copy pasted in the config.js and changed the API and pws. restarted MM and got directly what I needed. Strange. very strange.
                                    • brobergB
                                      broberg Project Sponsor
                                      I’ve had it malfunction a couple of time to, but it usually starts working again after a couple of hours/next day. Seems to me that i’s a connection issue since I don’t change anything for it to work again.
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @Preve
                                        @Preve when I applied for the API Key it wasn’t working for a while as well. I had to wait until it was ready to use in their system.
                                          Preve @broberg
                                          @broberg But when the API-key is wrong or maybe too soon used, wouldn’t you get any kind of loading error? In my case there was nothing showing on my screen.
                                          • yawnsY
                                            Yes, it does show this alert. As I said … Press F12, change to console and look for errors. I removed one character in my appid, and this is what happens:
