    Default Weather module not loading and no error showing.
    31 Posts 9 Posters 42.4k Views 8 Watching
    • yawnsY Offline
      yawns Moderator @Preve
      @Preve
      Please post your config, but replace your personal keys/calendar links with XXX
        Preve
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: 'en',
        	timeFormat: 24,
        	units: 'metric',
        			module: 'alert',
        			module: "updatenotification",
        			position: "top_bar"
        			module: 'clock',
        			position: 'top_left'
        			module: 'calendar',
        			header: 'Personal Calendar',
        			position: 'top_left',
                                                        symbol: 'calendar-check-o ',
                                                        url: 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
        			module: 'compliments',
        			position: 'lower_third'
        			module: 'currentweather',
        			position: 'top_right',
        				locationID: '2802154',
        				appid: 'XXXXXXXXXXXXXXXXXXXXXXX'
        			module: 'weatherforecast',
        			header: 'Weather Forecast',
        			module: 'newsfeed',
        			position: 'bottom_bar',
        				feeds: [
        						title: "HLN BE",
        						url: "http://www.hln.be/rss.xml"
        				showSourceTitle: true,
        				showPublishDate: true
        • yawnsY Offline
          yawns Moderator
          That in fact looks perfectly fine. Did you try to reboot your pi to check if currentweather comes up?
          Try to press F12 in the browser while MagicMirror is running and check the console for errors
            Preve
            Restarted MM a couple of times. I’ll reboot the PI and see what’s happening.
              Preve @Preve
              Nope, Rebooted the PI and still nothing.
              • yawnsY Offline
                yawns Moderator
                And console of your browser does not show a single error?
                  Preve
                  How do I get there? Sorry for noobish question. It runs full screen.
                  • yawnsY Offline
                    yawns Moderator
                    If you press F12 in your browser you should see a development interface, one is called console and should show information, warnings and - maybe - errors
                    • yawnsY Offline
                      yawns Moderator
                      I just tried your currentweather settings with my appid and instantly see the current weather. Did you check your appid again?
                        Preve
                        Registerd to the site, asked an API and that API shows in “my api” folder on the website. Already removed it and re-entered it.
                        • 1 / 4
