    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 114.9k Views 18 Watching
      Mar @Mar
      @Mar for anyone else who is getting this an npm rebuild fixes it. from here https://github.com/atom/apm/issues/635
        Jay
        Hey, thanks for advising us how to install the modules, but I´m still struggling to find a solution for me even after updating nodejs and npm to the latest builts…
        Similar error with corrected package.json.
        Unable to find electron-prebuilt's version number, either install it or specify an explicit version
        I even tried the npm rebuild @Mar suggested. My last attempt to get this working was updating electron to its newest version but this didn´t help either.
        Is there anything I could further try to install this module correctly?
          Mar @Jay
          @Jay I forgot what I did here to fix this issue. But to be honest after I got this working it still wasnt perfect. I ended going the route of a script on startup that controls the PIR sensor and its been perfect since and simple.
          • F Offline
            fox
            did you install the fix? or is this now obsolet?
            Issues With MMM-WatchDog known?
            https://forum.magicmirror.builders/post/29827
            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
              Jopyth Moderator @fox
              @fox This PR should have fixed the issue (it is merged into the master).
              Are you running MagicMirror 2.1.0? And is your PIR-Module up-to-date? Try updating both (see this and do it in both directories) to the newest version.
              F 1 Reply Last reply Reply Quote 1
              • F Offline
                fox @Jopyth
                @Jopyth said in [MMM-PIR-Sensor] Install failing:
                I deleted PIR Sensor completely. And made a new installation of this module and it installed without Problems. looks good from now
                • johnnyboyJ Offline
                  johnnyboy
                    STEFF92
                    Hi, i tried to install the module MMM-PIR-Sensor. I did it like its explained here:
                    https://github.com/paviro/MMM-PIR-Sensor
                    After installing the module i opened the config.js file an added:
                    			module: 'MMM-PIR-Sensor',
                    				sensorPIN: 23,
                                                    powerSaving: true,
                                                    relayPIN: none,
                                                    relayOnState: 1,
                    The way i connected the sensor is shown in the following picture:
                    alt text
                    But when i want to start the magic mirror it says that i have to add a correct config.js file.
                    What did i wrong? Please help me guys ;)
                    J johnnyboyJ 2 Replies Last reply Reply Quote 0
                      Jay @STEFF92
                      @STEFF92
                      Did you change the name of the config File from “config.js.sample” to “config.js”?
                        STEFF92 @Jay
                        @Jay yes i did. The basic modules like clock or weather are running but when i add the module for the PIR sensor in the config.js file i cant start the magic mirror
                          pjkoeleman
                          Delete the ‘,’ in te last line (relayOnState: 1)
                            johnnyboy @Jopyth
                              johnnyboy @STEFF92
                              johnnyboyJ 1 Reply Last reply Reply Quote 0
                                johnnyboy @johnnyboy
                                  STEFF92 @pjkoeleman
                                  @pjkoeleman Doesnt work :(
                                  johnnyboyJ P 2 Replies Last reply Reply Quote 0
                                    johnnyboy @STEFF92
                                      pjkoeleman @STEFF92
                                      @STEFF92
                                      What is not working;
                                      • Do you still have the problem with the config.sys, when post your config.sys here.
                                      • Is the PIR not switching off you screen?
                                        STEFF92 @johnnyboy
                                        @johnnyboy But it doesnt matter as long as i use the gpio that belongs to this pin or am i wrong?
                                          STEFF92 @pjkoeleman
                                          @pjkoeleman when i want to start the magic mirror it says that i should create a correct config.js file. But the only thing i added in my config.js file (which runs without the following lines) is:
                                          				sensorPIN: 23,
        powerSaving: true,
        relayPIN: none,
        relayOnState: 1,
                                            johnnyboy @STEFF92
                                            • 3 / 4
