    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 120.0k Views 18 Watching
    • JayJ
      Jay
      Hey, thanks for advising us how to install the modules, but I´m still struggling to find a solution for me even after updating nodejs and npm to the latest builts…
      Similar error with corrected package.json.
      Unable to find electron-prebuilt's version number, either install it or specify an explicit version
      I even tried the npm rebuild @Mar suggested. My last attempt to get this working was updating electron to its newest version but this didn´t help either.
      Is there anything I could further try to install this module correctly?
      M 1 Reply Last reply
        Mar @Jay
        @Jay I forgot what I did here to fix this issue. But to be honest after I got this working it still wasnt perfect. I ended going the route of a script on startup that controls the PIR sensor and its been perfect since and simple.
        • foxF
          fox
          did you install the fix? or is this now obsolet?
          Issues With MMM-WatchDog known?
          https://forum.magicmirror.builders/post/29827
          Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
          J 1 Reply Last reply
            Jopyth Moderator @fox
            @fox This PR should have fixed the issue (it is merged into the master).
            Are you running MagicMirror 2.1.0? And is your PIR-Module up-to-date? Try updating both (see this and do it in both directories) to the newest version.
            foxF 1 Reply Last reply
            • foxF
              fox @Jopyth
              @Jopyth said in [MMM-PIR-Sensor] Install failing:
              I deleted PIR Sensor completely. And made a new installation of this module and it installed without Problems. looks good from now
              • johnnyboyJ
                johnnyboy
                  STEFF92
                  Hi, i tried to install the module MMM-PIR-Sensor. I did it like its explained here:
                  https://github.com/paviro/MMM-PIR-Sensor
                  After installing the module i opened the config.js file an added:
                  			module: 'MMM-PIR-Sensor',
                  				sensorPIN: 23,
                                                  powerSaving: true,
                                                  relayPIN: none,
                                                  relayOnState: 1,
                  The way i connected the sensor is shown in the following picture:
                  alt text
                  But when i want to start the magic mirror it says that i have to add a correct config.js file.
                  What did i wrong? Please help me guys ;)
                  JayJ johnnyboyJ 2 Replies Last reply
                  • JayJ
                    Jay @STEFF92
                    @STEFF92
                    Did you change the name of the config File from “config.js.sample” to “config.js”?
                      STEFF92 @Jay
                      @Jay yes i did. The basic modules like clock or weather are running but when i add the module for the PIR sensor in the config.js file i cant start the magic mirror
                      • pjkoelemanP
                        pjkoeleman
                        Delete the ‘,’ in te last line (relayOnState: 1)
                        • johnnyboyJ
                          johnnyboy @Jopyth
                          • johnnyboyJ
                            johnnyboy @STEFF92
                            johnnyboyJ 1 Reply Last reply
                            • johnnyboyJ
                              johnnyboy @johnnyboy
                                STEFF92 @pjkoeleman
                                @pjkoeleman Doesnt work :(
                                johnnyboyJ pjkoelemanP 2 Replies Last reply
                                • johnnyboyJ
                                  johnnyboy @STEFF92
                                  • pjkoelemanP
                                    pjkoeleman @STEFF92
                                    @STEFF92
                                    What is not working;
                                    • Do you still have the problem with the config.sys, when post your config.sys here.
                                    • Is the PIR not switching off you screen?
                                      STEFF92 @johnnyboy
                                      @johnnyboy But it doesnt matter as long as i use the gpio that belongs to this pin or am i wrong?
                                        STEFF92 @pjkoeleman
                                        @pjkoeleman when i want to start the magic mirror it says that i should create a correct config.js file. But the only thing i added in my config.js file (which runs without the following lines) is:
                                        				sensorPIN: 23,
        powerSaving: true,
        relayPIN: none,
        relayOnState: 1,
                                        • johnnyboyJ
                                          johnnyboy @STEFF92
                                            STEFF92 @johnnyboy
                                            @johnnyboy yes i tried it like this :
                                            				sensorPIN: 23,
        powerSaving: true,
        relayPIN: none,
        relayOnState: 1
                                            But it dosent work. Same problem as before.
                                            johnnyboyJ strawberry 3.141S 2 Replies Last reply
                                            • 3 / 4
