    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 115.7k Views 18 Watching
    • F Offline
      fox @Jopyth
      @Jopyth said in [MMM-PIR-Sensor] Install failing:
      @fox This PR should have fixed the issue (it is merged into the master).
      Are you running MagicMirror 2.1.0? And is your PIR-Module up-to-date? Try updating both (see this and do it in both directories) to the newest version.
      I deleted PIR Sensor completely. And made a new installation of this module and it installed without Problems. looks good from now
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      • johnnyboyJ Offline
        johnnyboy
          STEFF92
          Hi, i tried to install the module MMM-PIR-Sensor. I did it like its explained here:
          https://github.com/paviro/MMM-PIR-Sensor
          After installing the module i opened the config.js file an added:
          			module: 'MMM-PIR-Sensor',
          				sensorPIN: 23,
                                          powerSaving: true,
                                          relayPIN: none,
                                          relayOnState: 1,
          The way i connected the sensor is shown in the following picture:
          alt text
          But when i want to start the magic mirror it says that i have to add a correct config.js file.
          What did i wrong? Please help me guys ;)
          J johnnyboyJ 2 Replies Last reply Reply Quote 0
            Jay @STEFF92
            @STEFF92
            Did you change the name of the config File from “config.js.sample” to “config.js”?
              STEFF92 @Jay
              @Jay yes i did. The basic modules like clock or weather are running but when i add the module for the PIR sensor in the config.js file i cant start the magic mirror
                pjkoeleman
                Delete the ‘,’ in te last line (relayOnState: 1)
                  johnnyboy @Jopyth
                    johnnyboy @STEFF92
                    johnnyboyJ 1 Reply Last reply Reply Quote 0
                      johnnyboy @johnnyboy
                        STEFF92 @pjkoeleman
                        @pjkoeleman Doesnt work :(
                        johnnyboyJ P 2 Replies Last reply Reply Quote 0
                          johnnyboy @STEFF92
                            pjkoeleman @STEFF92
                            @STEFF92
                            What is not working;
                            • Do you still have the problem with the config.sys, when post your config.sys here.
                            • Is the PIR not switching off you screen?
                              STEFF92 @johnnyboy
                              @johnnyboy But it doesnt matter as long as i use the gpio that belongs to this pin or am i wrong?
                                STEFF92 @pjkoeleman
                                @pjkoeleman when i want to start the magic mirror it says that i should create a correct config.js file. But the only thing i added in my config.js file (which runs without the following lines) is:
                                				sensorPIN: 23,
        powerSaving: true,
        relayPIN: none,
        relayOnState: 1,
                                  johnnyboy @STEFF92
                                    STEFF92 @johnnyboy
                                    @johnnyboy yes i tried it like this :
                                    				sensorPIN: 23,
        powerSaving: true,
        relayPIN: none,
        relayOnState: 1
                                    But it dosent work. Same problem as before.
                                    johnnyboyJ strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                      johnnyboy @STEFF92
                                      • strawberry 3.141S Offline
                                        strawberry 3.141 Project Sponsor Module Developer @STEFF92
                                        @STEFF92 none is not a valid js value either use
                                            sensorPIN: 23,
                                            powerSaving: true,
                                            relayPIN: false,
                                            relayOnState: 1
                                        or like this, because relayPIN is set to false by default
                                            sensorPIN: 23,
                                            powerSaving: true,
                                            relayOnState: 1
                                          STEFF92 @strawberry 3.141
                                          @strawberry-3.141 Thanks, now the config file and the magic mirror surface are running but there is no response from the sensor. i have moved the potentiometer but the screen doesnt turn off. Do you know any possible mistake i could have made?
                                            @STEFF92 I guess you might defined the wrong pin number according on your setup you use gpio23 which is pin 16 in this diagram https://forum.magicmirror.builders/uploads/files/1485851152518-raspberry-pi-15b.jpg, but I never did something with the gpio of the pi
                                            • 3 / 4
