    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 118.6k Views 18 Watching
    • F
      fox
      did you install the fix? or is this now obsolet?
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        Jopyth Moderator @fox
        @fox This PR should have fixed the issue (it is merged into the master).
        Are you running MagicMirror 2.1.0? And is your PIR-Module up-to-date? Try updating both (see this and do it in both directories) to the newest version.
        F 1 Reply Last reply Reply Quote 1
        • F
          fox @Jopyth
          @Jopyth said in [MMM-PIR-Sensor] Install failing:
          I deleted PIR Sensor completely. And made a new installation of this module and it installed without Problems. looks good from now
          • johnnyboyJ
            johnnyboy
              STEFF92
              Hi, i tried to install the module MMM-PIR-Sensor. I did it like its explained here:
              https://github.com/paviro/MMM-PIR-Sensor
              After installing the module i opened the config.js file an added:
              			module: 'MMM-PIR-Sensor',
              				sensorPIN: 23,
                                              powerSaving: true,
                                              relayPIN: none,
                                              relayOnState: 1,
              The way i connected the sensor is shown in the following picture:
              alt text
              But when i want to start the magic mirror it says that i have to add a correct config.js file.
              What did i wrong? Please help me guys ;)
              J johnnyboyJ 2 Replies Last reply Reply Quote 0
                Jay @STEFF92
                @STEFF92
                Did you change the name of the config File from “config.js.sample” to “config.js”?
                  STEFF92 @Jay
                  @Jay yes i did. The basic modules like clock or weather are running but when i add the module for the PIR sensor in the config.js file i cant start the magic mirror
                    pjkoeleman
                    Delete the ‘,’ in te last line (relayOnState: 1)
                    • johnnyboyJ
                      johnnyboy @Jopyth
                      • johnnyboyJ
                        johnnyboy @STEFF92
                        johnnyboyJ 1 Reply Last reply Reply Quote 0
                        • johnnyboyJ
                          johnnyboy @johnnyboy
                            STEFF92 @pjkoeleman
                            @pjkoeleman Doesnt work :(
                            johnnyboyJ P 2 Replies Last reply Reply Quote 0
                            • johnnyboyJ
                              johnnyboy @STEFF92
                                pjkoeleman @STEFF92
                                @STEFF92
                                What is not working;
                                • Do you still have the problem with the config.sys, when post your config.sys here.
                                • Is the PIR not switching off you screen?
                                  STEFF92 @johnnyboy
                                  @johnnyboy But it doesnt matter as long as i use the gpio that belongs to this pin or am i wrong?
                                    STEFF92 @pjkoeleman
                                    @pjkoeleman when i want to start the magic mirror it says that i should create a correct config.js file. But the only thing i added in my config.js file (which runs without the following lines) is:
                                    				sensorPIN: 23,
        powerSaving: true,
        relayPIN: none,
        relayOnState: 1,
                                    • johnnyboyJ
                                      johnnyboy @STEFF92
                                        STEFF92 @johnnyboy
                                        @johnnyboy yes i tried it like this :
                                        				sensorPIN: 23,
        powerSaving: true,
        relayPIN: none,
        relayOnState: 1
                                        But it dosent work. Same problem as before.
                                        johnnyboyJ strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                        • johnnyboyJ
                                          johnnyboy @STEFF92
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @STEFF92
                                            @STEFF92 none is not a valid js value either use
                                                sensorPIN: 23,
                                                powerSaving: true,
                                                relayPIN: false,
                                                relayOnState: 1
                                            or like this, because relayPIN is set to false by default
                                                sensorPIN: 23,
                                                powerSaving: true,
                                                relayOnState: 1
                                            • 3 / 4
