    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 119.9k Views 18 Watching
      STEFF92 @Jay
      @Jay yes i did. The basic modules like clock or weather are running but when i add the module for the PIR sensor in the config.js file i cant start the magic mirror
      • pjkoelemanP
        pjkoeleman
        Delete the ‘,’ in te last line (relayOnState: 1)
        • johnnyboyJ
          johnnyboy @Jopyth
          • johnnyboyJ
            johnnyboy @STEFF92
            johnnyboyJ 1 Reply Last reply
            • johnnyboyJ
              johnnyboy @johnnyboy
                STEFF92 @pjkoeleman
                @pjkoeleman Doesnt work :(
                johnnyboyJ pjkoelemanP 2 Replies Last reply
                • johnnyboyJ
                  johnnyboy @STEFF92
                  • pjkoelemanP
                    pjkoeleman @STEFF92
                    @STEFF92
                    What is not working;
                    • Do you still have the problem with the config.sys, when post your config.sys here.
                    • Is the PIR not switching off you screen?
                      STEFF92 @johnnyboy
                      @johnnyboy But it doesnt matter as long as i use the gpio that belongs to this pin or am i wrong?
                        STEFF92 @pjkoeleman
                        @pjkoeleman when i want to start the magic mirror it says that i should create a correct config.js file. But the only thing i added in my config.js file (which runs without the following lines) is:
                        			module: 'MMM-PIR-Sensor',
                        				sensorPIN: 23,
                                                        powerSaving: true,
                                                        relayPIN: none,
                                                        relayOnState: 1,
                        • johnnyboyJ
                          johnnyboy @STEFF92
                            STEFF92 @johnnyboy
                            @johnnyboy yes i tried it like this :
                            				sensorPIN: 23,
                                                            powerSaving: true,
                                                            relayPIN: none,
                                                            relayOnState: 1
                            But it dosent work. Same problem as before.
                            johnnyboyJ strawberry 3.141S 2 Replies Last reply
                            • johnnyboyJ
                              johnnyboy @STEFF92
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @STEFF92
                                @STEFF92 none is not a valid js value either use
                                    sensorPIN: 23,
                                    powerSaving: true,
                                    relayPIN: false,
                                    relayOnState: 1
                                or like this, because relayPIN is set to false by default
                                    sensorPIN: 23,
                                    powerSaving: true,
                                    relayOnState: 1
                                  STEFF92 @strawberry 3.141
                                  @strawberry-3.141 Thanks, now the config file and the magic mirror surface are running but there is no response from the sensor. i have moved the potentiometer but the screen doesnt turn off. Do you know any possible mistake i could have made?
                                  • strawberry 3.141S
                                    @STEFF92 I guess you might defined the wrong pin number according on your setup you use gpio23 which is pin 16 in this diagram https://forum.magicmirror.builders/uploads/files/1485851152518-raspberry-pi-15b.jpg, but I never did something with the gpio of the pi
                                    • O
                                      Oliver_Tooth
                                      Hi all,
                                      I’ve been trying to instal this module, but i’m bumping into the issue of needing node module 53, as it was compiled with 48. I’ve been at this all day and i’m really struggling. Can anyone offer any advice? Thanks in advance!
                                      yawnsY 1 Reply Last reply
                                      • yawnsY
                                        yawns Moderator @Oliver_Tooth
                                        @Oliver_Tooth
                                        Please search this forum for “version mismatch”. I’m on my smartphone right now, otherwise I would post the command necessary.
                                        You need to rebuild the module with a special command providing the version info related to your system
                                        O 1 Reply Last reply
                                        • O
                                          Oliver_Tooth @yawns
                                          @yawns Cheers for this. I’ve had a quick browse but i’m struggling to find anything that works. If your able to post the command whenever you’re able to i’d really appreciate it! thanks.
                                          yawnsY 2 Replies Last reply
                                          • yawnsY
                                            @Oliver_Tooth
                                            Sure, tomorrow morning
                                            • 3 / 4
