    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 114.9k Views 18 Watching
    • johnnyboyJ Offline
      johnnyboy @Jopyth
        johnnyboy @STEFF92
        johnnyboyJ 1 Reply Last reply Reply Quote 0
          johnnyboy @johnnyboy
            STEFF92 @pjkoeleman
            @pjkoeleman Doesnt work :(
            johnnyboyJ P 2 Replies Last reply Reply Quote 0
              johnnyboy @STEFF92
                pjkoeleman @STEFF92
                @STEFF92
                What is not working;
                • Do you still have the problem with the config.sys, when post your config.sys here.
                • Is the PIR not switching off you screen?
                  STEFF92 @johnnyboy
                  @johnnyboy But it doesnt matter as long as i use the gpio that belongs to this pin or am i wrong?
                    STEFF92 @pjkoeleman
                    @pjkoeleman when i want to start the magic mirror it says that i should create a correct config.js file. But the only thing i added in my config.js file (which runs without the following lines) is:
                    			module: 'MMM-PIR-Sensor',
                    				sensorPIN: 23,
                                                    powerSaving: true,
                                                    relayPIN: none,
                                                    relayOnState: 1,
                      johnnyboy @STEFF92
                        STEFF92 @johnnyboy
                        @johnnyboy yes i tried it like this :
                        				sensorPIN: 23,
                                                        powerSaving: true,
                                                        relayPIN: none,
                                                        relayOnState: 1
                        But it dosent work. Same problem as before.
                        johnnyboyJ strawberry 3.141S 2 Replies Last reply Reply Quote 0
                          johnnyboy @STEFF92
                          • strawberry 3.141S Offline
                            strawberry 3.141 Project Sponsor Module Developer @STEFF92
                            @STEFF92 none is not a valid js value either use
                                sensorPIN: 23,
                                powerSaving: true,
                                relayPIN: false,
                                relayOnState: 1
                            or like this, because relayPIN is set to false by default
                                sensorPIN: 23,
                                powerSaving: true,
                                relayOnState: 1
                              STEFF92 @strawberry 3.141
                              @strawberry-3.141 Thanks, now the config file and the magic mirror surface are running but there is no response from the sensor. i have moved the potentiometer but the screen doesnt turn off. Do you know any possible mistake i could have made?
                                @STEFF92 I guess you might defined the wrong pin number according on your setup you use gpio23 which is pin 16 in this diagram https://forum.magicmirror.builders/uploads/files/1485851152518-raspberry-pi-15b.jpg, but I never did something with the gpio of the pi
                                • O Offline
                                  Oliver_Tooth
                                  Hi all,
                                  I’ve been trying to instal this module, but i’m bumping into the issue of needing node module 53, as it was compiled with 48. I’ve been at this all day and i’m really struggling. Can anyone offer any advice? Thanks in advance!
                                  • Y Offline
                                    yawns Moderator @Oliver_Tooth
                                    @Oliver_Tooth
                                    Please search this forum for “version mismatch”. I’m on my smartphone right now, otherwise I would post the command necessary.
                                    You need to rebuild the module with a special command providing the version info related to your system
                                    • O Offline
                                      Oliver_Tooth @yawns
                                      @yawns Cheers for this. I’ve had a quick browse but i’m struggling to find anything that works. If your able to post the command whenever you’re able to i’d really appreciate it! thanks.
                                      Y 2 Replies Last reply Reply Quote 0
                                      • Y Offline
                                        @Oliver_Tooth
                                        Sure, tomorrow morning
                                        • Y Offline
                                          @Oliver_Tooth
                                          all right …
                                          Open a terminal and do this:
                                          npm list | grep electron
                                          You will see something like this:
                                          ├─┬ electron-prebuilt@1.4.5
                                          │ ├─┬ electron-download@3.0.1
                                          npm ERR! peer dep missing: grunt@~0.4.0, required by grunt-yamllint@0.2.0
                                          Note the version of electron, in this case it is 1.4.5, if it is different for you please replace the version accordingly.
                                          Afterwards run this:
                                          cd modules/MMM-PIR-Sensor
                                          npm rebuild --runtime=electron --target=1.4.5 --disturl=https://atom.io/download/atom-shell --abi=50
                                          Now the module should not throw a version mismatch error any more.
                                          O 2 Replies Last reply Reply Quote 0
                                          • O Offline
                                            Oliver_Tooth @yawns
                                            @yawns Hi! my prebuilt version was slightly different, so i changed that in the target= field, does the abi= number need to be 53, not 50? I’ve tried it as 50 and it’s still throwing the error.
                                            • 3 / 4
