    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 118.6k Views 18 Watching
    • johnnyboyJ
      johnnyboy @johnnyboy
        STEFF92 @pjkoeleman
        @pjkoeleman Doesnt work :(
        johnnyboyJ P 2 Replies Last reply Reply Quote 0
        • johnnyboyJ
          johnnyboy @STEFF92
            pjkoeleman @STEFF92
            @STEFF92
            What is not working;
            • Do you still have the problem with the config.sys, when post your config.sys here.
            • Is the PIR not switching off you screen?
              STEFF92 @johnnyboy
              @johnnyboy But it doesnt matter as long as i use the gpio that belongs to this pin or am i wrong?
                STEFF92 @pjkoeleman
                @pjkoeleman when i want to start the magic mirror it says that i should create a correct config.js file. But the only thing i added in my config.js file (which runs without the following lines) is:
                			module: 'MMM-PIR-Sensor',
                				sensorPIN: 23,
                                                powerSaving: true,
                                                relayPIN: none,
                                                relayOnState: 1,
                johnnyboyJ 1 Reply Last reply Reply Quote 0
                • johnnyboyJ
                  johnnyboy @STEFF92
                    STEFF92 @johnnyboy
                    @johnnyboy yes i tried it like this :
                    				sensorPIN: 23,
                                                    powerSaving: true,
                                                    relayPIN: none,
                                                    relayOnState: 1
                    But it dosent work. Same problem as before.
                    johnnyboyJ strawberry 3.141S 2 Replies Last reply Reply Quote 0
                    • johnnyboyJ
                      johnnyboy @STEFF92
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @STEFF92
                        @STEFF92 none is not a valid js value either use
                            sensorPIN: 23,
                            powerSaving: true,
                            relayPIN: false,
                            relayOnState: 1
                        or like this, because relayPIN is set to false by default
                            sensorPIN: 23,
                            powerSaving: true,
                            relayOnState: 1
                          STEFF92 @strawberry 3.141
                          @strawberry-3.141 Thanks, now the config file and the magic mirror surface are running but there is no response from the sensor. i have moved the potentiometer but the screen doesnt turn off. Do you know any possible mistake i could have made?
                          • strawberry 3.141S
                            @STEFF92 I guess you might defined the wrong pin number according on your setup you use gpio23 which is pin 16 in this diagram https://forum.magicmirror.builders/uploads/files/1485851152518-raspberry-pi-15b.jpg, but I never did something with the gpio of the pi
                            • O
                              Oliver_Tooth
                              Hi all,
                              I’ve been trying to instal this module, but i’m bumping into the issue of needing node module 53, as it was compiled with 48. I’ve been at this all day and i’m really struggling. Can anyone offer any advice? Thanks in advance!
                              • Y
                                yawns Moderator @Oliver_Tooth
                                @Oliver_Tooth
                                Please search this forum for “version mismatch”. I’m on my smartphone right now, otherwise I would post the command necessary.
                                You need to rebuild the module with a special command providing the version info related to your system
                                • O
                                  Oliver_Tooth @yawns
                                  @yawns Cheers for this. I’ve had a quick browse but i’m struggling to find anything that works. If your able to post the command whenever you’re able to i’d really appreciate it! thanks.
                                  Y 2 Replies Last reply Reply Quote 0
                                  • Y
                                    @Oliver_Tooth
                                    Sure, tomorrow morning
                                    • Y
                                      @Oliver_Tooth
                                      all right …
                                      Open a terminal and do this:
                                      npm list | grep electron
                                      You will see something like this:
                                      ├─┬ electron-prebuilt@1.4.5
                                      │ ├─┬ electron-download@3.0.1
                                      npm ERR! peer dep missing: grunt@~0.4.0, required by grunt-yamllint@0.2.0
                                      Note the version of electron, in this case it is 1.4.5, if it is different for you please replace the version accordingly.
                                      Afterwards run this:
                                      cd modules/MMM-PIR-Sensor
                                      npm rebuild --runtime=electron --target=1.4.5 --disturl=https://atom.io/download/atom-shell --abi=50
                                      Now the module should not throw a version mismatch error any more.
                                      O 2 Replies Last reply Reply Quote 0
                                      • O
                                        Oliver_Tooth @yawns
                                        @yawns Hi! my prebuilt version was slightly different, so i changed that in the target= field, does the abi= number need to be 53, not 50? I’ve tried it as 50 and it’s still throwing the error.
                                        • O
                                          Oliver_Tooth @yawns
                                          @yawns I’ve been reading up further on this, and i’ve found that version 53 doesn’t actually exist yet, and 51 is currently the latest. Have you any idea how i’d get this to work with this information? thanks.
                                          • T
                                            thoimi
                                            hi there,
                                            finally i had the time to work / finish my magic mirror.
                                            Just the PIR-Sensor-Plugin doesn’t work… After I updated the MM to 2.1.1 I did a fresh install of the script which worked without an error. Yay!
                                            BUT the script is not turning off my monitor… I connected the sensor to GPIO04 / BCM07 and tried to change the SensorPin-Number (from 4 to 7)
                                            I put the sensor in a black box so the display should shut down after starting Magic Mirror, right?
                                            • 4 / 4
