    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 118.6k Views 18 Watching
    • Y
      yawns Moderator @Oliver_Tooth
      @Oliver_Tooth
      Please search this forum for “version mismatch”. I’m on my smartphone right now, otherwise I would post the command necessary.
      You need to rebuild the module with a special command providing the version info related to your system
      • O
        Oliver_Tooth @yawns
        @yawns Cheers for this. I’ve had a quick browse but i’m struggling to find anything that works. If your able to post the command whenever you’re able to i’d really appreciate it! thanks.
        Y 2 Replies Last reply Reply Quote 0
        • Y
          @Oliver_Tooth
          Sure, tomorrow morning
          • Y
            @Oliver_Tooth
            all right …
            Open a terminal and do this:
            npm list | grep electron
            You will see something like this:
            ├─┬ electron-prebuilt@1.4.5
            │ ├─┬ electron-download@3.0.1
            npm ERR! peer dep missing: grunt@~0.4.0, required by grunt-yamllint@0.2.0
            Note the version of electron, in this case it is 1.4.5, if it is different for you please replace the version accordingly.
            Afterwards run this:
            cd modules/MMM-PIR-Sensor
            npm rebuild --runtime=electron --target=1.4.5 --disturl=https://atom.io/download/atom-shell --abi=50
            Now the module should not throw a version mismatch error any more.
            O 2 Replies Last reply Reply Quote 0
            • O
              Oliver_Tooth @yawns
              @yawns Hi! my prebuilt version was slightly different, so i changed that in the target= field, does the abi= number need to be 53, not 50? I’ve tried it as 50 and it’s still throwing the error.
              • O
                Oliver_Tooth @yawns
                @yawns I’ve been reading up further on this, and i’ve found that version 53 doesn’t actually exist yet, and 51 is currently the latest. Have you any idea how i’d get this to work with this information? thanks.
                • T
                  thoimi
                  hi there,
                  finally i had the time to work / finish my magic mirror.
                  Just the PIR-Sensor-Plugin doesn’t work… After I updated the MM to 2.1.1 I did a fresh install of the script which worked without an error. Yay!
                  BUT the script is not turning off my monitor… I connected the sensor to GPIO04 / BCM07 and tried to change the SensorPin-Number (from 4 to 7)
                  I put the sensor in a black box so the display should shut down after starting Magic Mirror, right?
                    Richard238
                    Hmmmm, black screen, and nothing on a browser at http://192.168.n.nn:8080/ either.
                    		module: 'MMM-PIR-Sensor',
                    		sensorPIN: 22,
                                    powerSaving: true,
                                    relayPIN: false,
                                    powerSavingDelay: 0,
                                    relayOnState: 1
                      pepemujica
                      Do I need anything else than the raspi, cable and pir sensor?
                      An arduino for example?
                      Kind regards
                      • Y
                        yawns Moderator @pepemujica
                        @pepemujica
                        No. You can connect the PIR sensor to the GPIO pins of your raspberry (make sure your wiring is proper) and work with the PIR sensor after installing the specific libraries
                        • 4 / 4
