    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 120.0k Views 18 Watching
    • JayJ
      Jay @STEFF92
      @STEFF92
      Did you change the name of the config File from “config.js.sample” to “config.js”?
        STEFF92 @Jay
        @Jay yes i did. The basic modules like clock or weather are running but when i add the module for the PIR sensor in the config.js file i cant start the magic mirror
        • pjkoelemanP
          pjkoeleman
          Delete the ‘,’ in te last line (relayOnState: 1)
          • johnnyboyJ
            johnnyboy @Jopyth
            • johnnyboyJ
              johnnyboy @STEFF92
              johnnyboyJ 1 Reply Last reply
              • johnnyboyJ
                johnnyboy @johnnyboy
                  STEFF92 @pjkoeleman
                  @pjkoeleman Doesnt work :(
                  johnnyboyJ pjkoelemanP 2 Replies Last reply
                  • johnnyboyJ
                    johnnyboy @STEFF92
                    • pjkoelemanP
                      pjkoeleman @STEFF92
                      @STEFF92
                      What is not working;
                      • Do you still have the problem with the config.sys, when post your config.sys here.
                      • Is the PIR not switching off you screen?
                        STEFF92 @johnnyboy
                        @johnnyboy But it doesnt matter as long as i use the gpio that belongs to this pin or am i wrong?
                          STEFF92 @pjkoeleman
                          @pjkoeleman when i want to start the magic mirror it says that i should create a correct config.js file. But the only thing i added in my config.js file (which runs without the following lines) is:
                          			module: 'MMM-PIR-Sensor',
                          				sensorPIN: 23,
                                                          powerSaving: true,
                                                          relayPIN: none,
                                                          relayOnState: 1,
                          • johnnyboyJ
                            johnnyboy @STEFF92
                              STEFF92 @johnnyboy
                              @johnnyboy yes i tried it like this :
                              				sensorPIN: 23,
                                                              powerSaving: true,
                                                              relayPIN: none,
                                                              relayOnState: 1
                              But it dosent work. Same problem as before.
                              johnnyboyJ strawberry 3.141S 2 Replies Last reply
                              • johnnyboyJ
                                johnnyboy @STEFF92
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @STEFF92
                                  @STEFF92 none is not a valid js value either use
                                      sensorPIN: 23,
                                      powerSaving: true,
                                      relayPIN: false,
                                      relayOnState: 1
                                  or like this, because relayPIN is set to false by default
                                      sensorPIN: 23,
                                      powerSaving: true,
                                      relayOnState: 1
                                    STEFF92 @strawberry 3.141
                                    @strawberry-3.141 Thanks, now the config file and the magic mirror surface are running but there is no response from the sensor. i have moved the potentiometer but the screen doesnt turn off. Do you know any possible mistake i could have made?
                                    • strawberry 3.141S
                                      @STEFF92 I guess you might defined the wrong pin number according on your setup you use gpio23 which is pin 16 in this diagram https://forum.magicmirror.builders/uploads/files/1485851152518-raspberry-pi-15b.jpg, but I never did something with the gpio of the pi
                                      • O
                                        Oliver_Tooth
                                        Hi all,
                                        I’ve been trying to instal this module, but i’m bumping into the issue of needing node module 53, as it was compiled with 48. I’ve been at this all day and i’m really struggling. Can anyone offer any advice? Thanks in advance!
                                        yawnsY 1 Reply Last reply
                                        • yawnsY
                                          yawns Moderator @Oliver_Tooth
                                          @Oliver_Tooth
                                          Please search this forum for “version mismatch”. I’m on my smartphone right now, otherwise I would post the command necessary.
                                          You need to rebuild the module with a special command providing the version info related to your system
                                          O 1 Reply Last reply
                                          • O
                                            Oliver_Tooth @yawns
                                            @yawns Cheers for this. I’ve had a quick browse but i’m struggling to find anything that works. If your able to post the command whenever you’re able to i’d really appreciate it! thanks.
                                            yawnsY 2 Replies Last reply
                                            • 3 / 4
